Old 01-20-2007, 03:39 PM
Alfiegerner Alfiegerner is offline
Hauppauge 45 button remote - Guide and Home buttons don't work
Has anyone seen this?
I use the hauppauge 45 button remote that came with a pvr-150 and a Nova t (90002) with no problems. Then recently I bought a nova t 500 dual dvb-t tuner and sage does not register anything when I press the guide and home buttons?
Any ideas?
Old 01-20-2007, 04:27 PM
Nothing else changed other than installing the new tuner?
What happens when you use those commands via the keyboard? The default keys are Home and Ctrl+X for those buttons. Maybe some system-wide hot keys got set up with the new tuner's software.
Old 01-20-2007, 06:28 PM
The keyboard shortcuts work fine. The remote keys do not work at all though, even when used in the customise --> link ir command screen.
Old 01-20-2007, 10:09 PM
You're using the Hauppauge remote, not the MCE remote from a Hauppauge MCE kit?
IR.exe has been restarted, SageTV has focus, and there is still a [SageTV] section in irremote.ini (found in your Windows directory)?
Have you modified irremote.ini?
