Old 10-08-2007, 11:35 AM
garyellis garyellis is offline
installing new versions of customizations
I just want to make sure I have the process right for installing new versions of customizations..
I have the latest version of Sage 6.2..with several customizations loaded
1) go to set up --> detailled setup --> advanced -->
SageTV application package ---> SageTV3.xml (this gets me back to the start, like when I first downloaded and installed 6.2)
2) Once that is loaded..I will then download and expand each of the latest versions of the customizations. (updates for new customs...but, is it ok to write over the old ones?)
3) Then, set up --> detailled setup --> advanced --> Import SageTV application package ---> and I load each one as normal.
is this correct?
Gary Ellis
Old 10-08-2007, 12:42 PM
ke6guj ke6guj is offline
looks good.
you can usually overwrite the old import files with the new import files (unless noted otherwise, haven't seen this).
The way of going back to the original SageTV3.xml and reimporting all the currently wanted customizations is the best way to do it. That way you don't have any issues with reimporting an import over itself.
edit: IF you have a lot of plugins that you import, you may want to look at flachbar's STVi importer, makes quick work of batch imports.
- Jack
Customizations karma SageTV Mac Edition 0 07-22-2007 11:47 PM
6.2.4 AC3 and player/transcoder versions twieder SageTV Beta Test Software 11 07-02-2007 06:30 PM
Customizations and MediaMVP rerooks SageTV Customizations 3 02-05-2007 08:45 AM
MVP Firmware Versions mdnttoker SageTV Media Extender 10 10-23-2006 05:31 PM
Customizations Compatible w/ SageTV 4 mightyt SageTV Customizations 2 11-21-2005 01:41 AM
