Old 05-05-2015, 06:36 PM
Rob23 Rob23 is offline
YouTube down again
I'm getting the, "Error: The requested media file was not found on the server," message again on all videos. The last time this occurred, JREkiwi uploaded the "YouTube Fix" plugin that solved the issue.
Anyone else getting this error?
Any one able to update the "YouTube Fix" plugin?
Old 05-06-2015, 11:16 AM
wubdich's Avatar
wubdich wubdich is offline
Probably YouTube is dead for SageTV as they retired version 2 of their API. But SageTv is not the only victim - have a look at http://www.eteknix.com/youtube-endin...tvs-smart-tvs/ . Maybee YouTube will be revitalized if SageTV is Open Source and someone is coding the needed changes for version 3 of YouTube API.
Old 05-07-2015, 02:40 AM
Doesn't really need open source, as I believe the youtube integration is built into the UI.
Old 05-09-2015, 10:26 AM
Is it even possible to update SageTV to utilize v3 of YouTube's API? What would it take to do so?
Old 05-09-2015, 01:33 PM
tmiranda's Avatar
tmiranda tmiranda is offline
Sage needs to get to the video file and the YouTube APIs do not directly expose that. Sage doesn't use the APIs at all, it does a lot of scraping to get to the video link. The scraping logic needs to be updated and that's very possible in the STV, somebody just has to get around to doing it.
Old 05-09-2015, 03:08 PM
JREkiwi's Avatar
JREkiwi JREkiwi is offline
I've had a quick look and it is using the web API interface to do searches etc, but it also uses the RSS feeds that disappeared when API V2 stopped working. Probably still only needs an STV change to migrate it to using the V3 API calls although it might need a new API key. The Google documentation has lots of links to non-existent pages, so it's rather frustrating working through it.
John
Bye Bye YouTube? EdwardATeller SageTV Software 89 07-13-2015 06:23 AM
YouTube electron SageTV Software 1 02-16-2012 06:31 PM
Youtube and 6.6 bmac.to SageTV Software 4 12-02-2011 08:02 AM
YouTube fix for v6.6? Rezolution SageTV Software 4 07-29-2011 06:35 AM
Where is YouTube? robk SageTV Beta Test Software 6 03-08-2007 04:53 PM
