Old 08-14-2007, 04:59 PM
splicer splicer is offline
Netflix stvi
I am currently running SAGE 6.2.5 and can import the plug-in. In Sage Media center I could not. Do I need to set dynamic menus in 6.2.5 in order to create a menu item for it, and then would it just show up in Media Center? The menus are already dynamic in Media Center, however I could not import it right into Media Center, any help will be greatly appreciated.
Phil
Old 08-19-2007, 05:51 PM
Flips's Avatar
Flips Flips is offline
Yep. You also need to import the dynamic menu STV import, and once that is installed you need to go to your online services menu then edit that menu (right mouse button) and then add a menu item for the internal screen called netflix plugin.
hope that helps.
flips
STV Import: NetFlix DwarF SageTV Customizations 125 12-11-2011 02:16 PM
creating STVi matrix35 SageTV Studio 6 02-25-2007 06:48 PM
Netflix + SageMC jayrbrown77 SageMC Custom Interface 2 11-12-2006 06:48 AM
Translate STVi owilsky SageTV Studio 10 10-21-2006 07:46 AM
STVI loaded twice..help...please garyellis SageTV Software 7 07-28-2006 04:53 PM
