Old 08-10-2009, 06:06 PM
timg11's Avatar
timg11 timg11 is offline
Any method for channel volume compensation?
I have 20dB variations between the softest and loudest channels. This is not just between the HD-PVR and HDHomerun - there are differences between channels just on the HD-PVR. The differences are consistent, so it would be helpful if there was some compensation factor that could be applied to specific channels. Is there way to accomplish this?
HD300 extender with SageTV V9.1.10 (service mode), Running on Windows 7 (32 bit), E8400 3GHz dual core CPU, 4G RAM, Gigabyte GA-P35-DS3L motherboard. NVidia 8600GT; Viewsonic LCD on one output and Mitsubishi WD57734 HDTV via DVI/HDMI on other output. HDHomeRun HDHR5-4US tuner, Hauppauge 1512 HD-PVR2 connected to Google Fiber TV GFHD200.
Old 08-10-2009, 09:26 PM
stevech stevech is offline
It bedevils all the cable companies. I guess it is just sloppy maintenance. (another example of: no competition = no excellence)
When I worked in a TV station, we had to keep our levels in tight spec or the FCC would cite us.
Old 08-14-2009, 11:38 AM
banshee banshee is offline
Wouldn't it be relatively straight forward (assuming it made it up the priority lists) for Sage to allow manual adjustments to volume on a per-channel basis? And automatically modify volume when you change channels?
And I wonder if this could be done as a plug-in?
Old 08-14-2009, 01:01 PM
tahoetim tahoetim is offline
The experts can tell me if I am wrong but I suspect that Sage is actually causing the issue. Once in a blue moon, my volume drops very low when I change channels and then ramps back up to the normal level over 10 seconds.
The other thing that makes me suspicious is the fact that these volume swings never happened before Sage.
I am not a programmer but I wonder if Sage uses the volume on the card from the last user? If I am watching a show on card A and then change channels to card B, could card B put out the last volume setting it used? It's sort of like the second or two of video you see when you change channels.
Or am I all wet?
WHS server, PVR150, PVR500, 2 HD200, 2 placeshifter laptops
Old 08-14-2009, 05:34 PM
toricred's Avatar
toricred toricred is offline
It happens on the extenders as well so I believe that the problem is not the playback, but it might be the way Sage records.
Getting 5.1 from HD channel but TV ihas only 2 CH speaker=very low volume craigap SageTV Software 1 11-06-2008 12:21 AM
STVI: Feature Request, automatic per channel volume gain Humanzee SageTV Customizations 1 01-27-2006 07:25 PM
MCE remote users: are your volume / channel buttons hard to press jenkins_pete Hardware Support 2 02-01-2005 04:35 PM
dont want channel/show info when using volume up/down akel SageTV Software 3 01-28-2005 01:36 PM
Volume setting for each channel PaulG SageTV Software 0 11-06-2004 07:02 PM
