Old 07-22-2009, 08:04 PM
madas madas is offline
Sonicview receiver + toggle bit + USB-UIRT
Hello,
I have a SonicView 360 which seems to use the toggle bit to identify unique key presses. I.e.
first press of 1
first1 0000 0073 0000 000C 0020 0021 0020 0021 0040 0041 0020 0021 0020 0021 0020 0021 0020 0021 0040 0021 0020 0021 0020 0021 0020 0021 0020 0CCA
second press of 1
second1 0000 0073 0000 000C 0020 0021 0040 0021 0020 0041 0020 0021 0020 0021 0020 0021 0020 0021 0040 0021 0020 0021 0020 0021 0020 0021 0020 0CCB
As you can see, the codes alternate. The third press is the same as the 1st press.
I can handle this at a command line level using uutx (USB-UIRT) by alternating the codes. How can I handle this with Sage, can sage call a batch file for tuning?
Currently on channels that have two digits the same next to each other the receiver will only identify the first one, i.e. 200 shows as 20
Old 07-23-2009, 10:57 AM
quick fix would be to increase the inter-digit delay. The toggle bit devices will recognize the same code in a row after a certain delay of not getting anything.
Old 07-23-2009, 11:06 AM
Unfortunately the delay is about 5 seconds...and this is long enough that the channel change has already occured.
Any better way?
Old 07-23-2009, 12:29 PM
I believe you CAN change channels through command line (which would allow some batchfile usage).. do a search for exetuner
Old 07-23-2009, 01:05 PM
Thanks, i'll give it a try. That was from 2003 though. Would it still work?
usb-uirt and vip211 receiver DArthur Hardware Support 39 07-30-2010 08:40 AM
USB-Uirt As Blaster and Receiver problem Lightarrow Hardware Support 18 07-19-2009 05:55 AM
Problems setting up and using USB-UIRT with toggle codes (Dish VIP211) popechild Hardware Support 2 12-14-2008 02:54 PM
USB-UIRT +56 and Dish 811 Receiver Trebord Hardware Support 3 05-07-2007 04:01 PM
AWTThread Hang when using USB-UIRT as Receiver peternm22 Hardware Support 2 04-28-2007 08:58 PM
