Old 05-19-2011, 11:50 AM
madas madas is offline
Sage client always starts minimized
Hello,
I am running the sage client on the same machine as the server (in service mode)
I have ui/last_win_fs=true in my sageclient.prop file
When I start sage it goes full screen for about a second then minimizes to the taskbar. If I set ui/last_win_fs=false it launches into window mode ok.
Any ideas why it keeps minimizing?
I've checked ui/startup_type and set this to 0,1,2 and it doesn't change the behaviour of this.
Any ideas?
Thank you
Old 05-20-2011, 02:11 PM
frontlinegeek frontlinegeek is offline
Do you have Full Screen Exclusive turned on?
I have that issue when FSE is on. Turn that off and all is fine.
My contribution to the internet: https://www.youtube.com/user/frontlinegeek
Old 05-20-2011, 03:23 PM
panteragstk's Avatar
+1. I have the media center button mapped in eventghost to bring sage to the front so it really isn't an issue, but it would be nice if it didn't happen.
Old 05-22-2011, 12:47 PM
As mentioned, disable FSE. It's really not needed if you are using the EVR. What is happening is some other program is grabbing focus, and since you have sage set to be a full-screen exclusive app, it is minimizing.
Old 05-22-2011, 05:40 PM
babgvant babgvant is offline
If FSE doesn't work, file a bug report. On mid-level (and lower) GPUs you will see a marked improvement in PQ when it is enabled; the main reason is that it disables DWM composition, but giving exclusive access to the screen has other benefits as well.
babgvant.com | @babgvant | Missing Remote
Old 05-23-2011, 08:23 AM
I haven't noticed any PQ issues without having it enabled vs disabled. For some reason it stopped happening. I guess I won't worry about it.
Old 05-23-2011, 12:02 PM
If you don't see the difference don't sweat it . Every mid-level GPU I've tested has benefited to some degree, with the lowest end showing the most improvement when FSE is enabled.
Old 05-23-2011, 12:29 PM
I agree. When I used ati 3450 there was a big difference between FSE pq vs no FSE, but with the 8800GT (soon to be amd 6570) I don't see any difference.
Old 05-23-2011, 12:45 PM
Yeah, I've never tested a 8800GT but given its spec's I'd expect it to be outside the noticeable range.
Old 06-13-2011, 05:45 AM
disabling FSE fixed it for me.
Resuming DVD playback always starts back at the beginning on Sage client LehighBri SageTV Software 12 01-12-2010 11:57 AM
SageTV Client starts fullscreen but no focus IVB SageTV Software 1 12-30-2005 10:56 AM
Unfortunate behavior when fav #5 starts at 11:05pm but fav #15 starts at 11:00pm rmellor SageTV Software 16 03-23-2005 03:05 AM
Using remote control with Sage minimized? tabletsage SageTV Beta Test Software 6 02-11-2004 12:04 PM
My Client almost starts up but dies. jackP SageTV Beta Test Software 3 01-27-2004 03:41 PM
