Old 11-13-2018, 02:02 PM
dinki's Avatar
dinki dinki is offline
Time set to GMT for web server only
I started running Sage in a docker container and it is great.
One weird thing is that the Jetty webserver is showing the time in GMT/UTC . I entered the container using bash and the time/date show up correctly with the correct time zone. I did explicitly set the TZ as an environment variable to 'US/Chicago'. Sage itself is displaying the correct time in gui when I connect via a client.
Is this something configurable with the web server itself? This is making it pretty hard to use the EPG on the web page. Thanks
Intel Q6600 Quad 2.4GHZ, 8GB RAM, Win7 Pro SP1 64bit, 1 TB of Data
SageTV 9, Silicondust HDHomeRun x2 OTA
HD200
Old 11-13-2018, 05:44 PM
Not what is happening for you. I just checked my web server and the time is showing correct (running in unRAID docker). I'm not aware of any web server specific settings for TZ.
Old 11-14-2018, 08:25 AM
dinki's Avatar
I'm a dope (which you may have figured out by now). I tried setting the TZ variable by memory and it needed to be 'America/Chicago' not 'US/Chicago'. Once I made that change everything started working as it should.
Sorry for the bother.
HD200
Server Time Question dstanley SageTV Software 7 10-30-2013 07:03 PM
Server died to day, time for a new one lovingHDTV Hardware Support 15 12-12-2009 01:33 PM
new server time garbageman Hardware Support 2 10-07-2009 11:34 AM
Time for Server upgrade - best Windows OS? Scriber General Discussion 13 10-03-2009 12:21 PM
Sage Server Time bjterry62 SageTV Software 21 11-08-2007 11:16 AM
