Old 08-06-2008, 10:23 PM
jorton jorton is offline
Fast Forward / Rewind HDTV Problems
Is anyone else having problems with fast forwarding and rewinding HDTV?
I record HDTV via firewire (2 x motorola DCT6416) and some time in the spring my fast forward and rewinding started to jump all over the place. I have FF set to 30 seconds but it may jump and if I RW it goes to some random place.
I have been using the latest betas as soon as they are released on my server and my clients but still no fix.
I had to stop using the Comskip plugin for skipping comercials since it was jumping too far ahead or back.
I don't have any problems with SD content (2 x PVR500 Hauppauge) just HD from my firewire captures. FF and RW work fine with SD as well as the comskip stvi.
Any ideas? Could my cable company have changed something in the TS stream?
Jeremy
Old 08-07-2008, 07:56 PM
Conejo Conejo is offline
FF/RW issues are usually caused by
1. bad recordings (bad frames)
2. bad interface driver
2. codec or video driver issues
#1 could be checked with any software that looks for bad frames, live Video Redo
#2 & #3 might be solved by reinstalling or downloading current versions.
Old 08-11-2008, 05:16 PM
I did a little test and I added a second harddrive to my SageTV client PC and installed XP with everything exactly the same as my Vista install.
I am using PowerDVD 8 is the decoder for video and AC3 codec for passthrough of AC3 Dobly Digital and decoding of non Dolby Digital.
I have no skipping/timeline problems on my XP Sagetv Server or on the XP Sagetv Client.
Comskip works perfectly in XP and skips/advances to the correct spots marked using Showanalyzer.
Only in Vista do I get the random skipping/timeline problem.
Any other ideas? I really like the playback performance in Vista (VRM9 with the eye candy), I have to us Overlay in XP to get decent HD 1080i/P playback.
Jeremy
Old 08-11-2008, 06:44 PM
srothwell's Avatar
srothwell srothwell is offline
I have exactly the same problem, although it seems much less.
My wife biggest complaint is she will go back 10 seconds (REW) and it will jump back WAY more than 10 seconds.
It only seems to happen going back.
Old 08-11-2008, 06:56 PM
Originally Posted by jorton View Post
I have no skipping/timeline problems on my XP Sagetv Server or on the XP Sagetv Client. Only in Vista do I get the random skipping/timeline problem.
Ok. This would tell me that it's the Vista interaction with the codec or renderer.
Users have noted problems/conflicts with VISTA and the EVR (Enhanced Video Renderer) main driver
EVR Support Lagging Behind Competitors
Videos Won't Play w/ VMR9 Vista
Porblem with HD playback with Intel graphics under Vista
I'm not a Vista user, so I'll leave any questions to other forum members.
Old 08-11-2008, 08:36 PM
I also tried playing the files on my Vista machine in PowerDVD8 and had no problems using the mouse to navigate the timeline or FF/RW.
I only have the problem using the Sagetv Client installed on Vista so it looks a little like Sagetv and the Vista/Directshow problem I read about in this thread,
http://forums.sagetv.com/forums/show...=HD+FF+problem
They talk about a Vista HD Directshow problem in the thread and that it was supposed to be fixed in 6.4.x
I am using Beta 6.4.6 on my server and my vista client so doesn't look like it has been fixed.
Jeremy
Old 08-11-2008, 10:09 PM
We're now at 6.4.7rc
Old 08-12-2008, 08:47 AM
Just tried 6.4.7RC and I get the same problem on Vista using Sagetv as 6.4.6.
No luck.
Jeremy
Old 08-13-2008, 09:20 AM
bmac.to bmac.to is offline
I have the same symptoms - I am using Vista Ultimate 64-bit. I find the skip function to be fairly predictable but the ctrl-f ctrl-a (the 10 second ones) to be completely unpredictable.
I have only figured out how to make it even worse - try changing the 10 seconds to 5 seconds.
________
FREE XXX TUBES
Old 08-13-2008, 11:48 AM
mikesm mikesm is offline
Is this with windows and not with the extender? if so, this likely the old windows timeline bug that has never been fixed.
Server: Sage 6.5.9 - X2 3800+, DFI NF4 MB, 1 GB, 300 GB HD (system disk), NV 7600GS, - Windows XP SP2
Client 1: Sage 6.5.9 - E7200, Abit IP35 Pro, ATI 4850 with HDMI connect to Denon 3808CI and Sony A3000 SXRD TV
Client 2: HD200 connected to Denon 3808CI and A3000 SXRD TV
Client 3: Media MVP to 15" Toshiba LCD
Client 4: HD100 connected to Samsung 23" 720P LCD
Client 5: HD100 connected to Vizio VX37L
Old 08-13-2008, 01:07 PM
This is on a Windows Vista 32 Home Premium machine running the latest Sagetv Client. No problems on XP clients.
I also submitted a bug report last night.
Jeremy
Old 08-13-2008, 02:48 PM
Response to my Bug Submission,
"We're aware of this issue and will be releasing an updated demux component
in the near future that resolves it."
SageTV Support Team
SageTV, LLC
betatest@sagetv.com
http://www.sagetv.com/
Old 08-13-2008, 09:39 PM
SageTV Support Team
SageTV, LLC
betatest@sagetv.com
That's great news...
Old 08-18-2008, 08:54 PM
agover agover is offline
Just as a heads up - Im also seeing this problem under XP using cyberlink8 too.
It seems to be code related as the problem seems to have appeared in the 6.4 series of sage - in 6.3 I barely ever saw it.(ie once or twice total)
Im hoping this fix is in 6.4 release/stable though otherwise im going to have to pick up an extender...
Old 08-19-2008, 09:20 AM
ben_95sl1 ben_95sl1 is offline
I also got that email a few weeks ago, hopefully soon the demux update will come out...please, please.
Server: XP SP3, X2 BE 5000+, WD 1.5TB x 2, PVR150 & HD-PVR, USB-UIRT
Clients: HD300, HD100 x 2, Media MVP in a box somewhere
Old 08-22-2008, 08:35 AM
bryanzim bryanzim is offline
I just want to make sure that this issue doesn't get dropped. This has been an issue with Sage since I started using it back at V5.X.
The random skipping during rewind/fast forward has always happened for both SDTV and HDTV recordings. THe same files play fine in WMP and do not skip when moving around in the file.
Old 08-22-2008, 10:40 AM
The FF/RW issue in this thread was limited to SageTV running on the VISTA OS. The OP didn't have the issue under XP.
Are you running on Vista?
Old 08-22-2008, 05:31 PM
Yes, running Vista x64 SP1.
Old 12-15-2008, 09:32 PM
bstowers bstowers is offline
I have the same problem os the OP on my main system using the latest version as of this time (6.4.8). I run on Vista Home Premium 32 bit.
On my Sage Client system that runs on XP, I never see the issue.
I record using the Hauppage HD-PVR.
Has anyone ever found a fix for this?
Old 07-26-2009, 05:16 PM
defilm defilm is offline
Question Has this issue been resolved???
I have noticed this problem. I can play back an Mpeg2 program in entirety
with no issues, however if U try to skip commercials, it appears as if the
decoder loses sync, and it just continues to forward through the file.
Even if I rewind the file to the beginning, exit the front end, bring it back up
and play the selection again, it plays fine up until the point where I started to fast forward, then the playback just loses sync and moves to the end as if it were playing at 16x mode, even though I did not touch the FF key on the remote on playback this time.
I am using a HVR-1950 on a Dual core 2 1.8Ghz ITX MB, 2GB Ram, Vista Home. I am set to encode by : Hauppauge HVR USB2 Video Capture,
Format: Mpeg2-ps [Mpeg2-video 16:9 1080i29.97fps, AC3/384Kbs @48KHz 5.1]. Video Render: Overlay (even though VMR9 and EVR are available),
Mpeg2 Decode filter: Interviewo NonCSS Video Decoder for Hauppauge (Other options are MS Mpeg2 decoder, and SageTV Mpeg Video Decoder).
Audio Decoder: Sage TV Mpeg Audio Decoder. In advanced: 3D Acceleration is enabled as the video chipset on this ITX PC was designed for the purpose of being a DVR. SageTV SW: 6.5.9.204 , Java 1.6.0_13.
I am hoping this problem was resolved, or someone can help me out if it is a setting issue.
Sage PVR: "Pandora MP945-DR ITX System" Intel core Duo 2 x 1.8Ghz, 4GB 667Mhz DDram, SATA 500GB 7200RPM Drive, DVD+-RW, DVI-HDMI HD out, Component RGB Video out/S-Video out, TOS Optical 5.1 Audo out, USB2.0 external Hauppauge WIN-TV HVR-1950
Fast Forward like TiVo ? 73cuda SageTV Software 6 02-08-2017 10:02 AM
Fast forward and rewind hangs or freezes menace SageTV Software 3 02-23-2008 03:37 PM
Really odd HDTV behavior lovingHDTV SageTV Beta Test Software 3 02-23-2007 12:53 PM
Divco HDTV using componet input problems itbmils Hardware Support 0 01-15-2007 12:34 AM
Problems with Fast Forward ldavis SageTV Beta Test Software 0 04-14-2004 08:21 PM
