Old 08-24-2008, 12:58 PM
agover agover is offline
Recording shows on specific tuner?? How to?
Hi All,
I have recently added a new HD-PVR to my existing system.
At present I have 2 atsc tuners, 1 hd pvr and an older pvr250.
The problem I have is that the atsc tuners have the exact same channels as the HD pvr (the hdpvr has more channels - but it also has copies of those on the atsc tuners). The issue is that a few channels arent at all reliable over atsc - specifically NBC & FOX.
For whatever reason Sage has decided that since all the channels have the same name (and channel id) it has grouped them all together.
Im basically looking for a way to either specifically state that show X gets recorded on the hdpvr or for a way to separate the grouped channels so I can directly address the HD-PVR channels.
I know I can simply disable the effected channels on the two atsc tuners but I was hoping to keep them as standby (they are about 70-80% reliable so for unimportant things the channels would be fine).
Any ideas on how I can do this?
Ive done some searches but so far I havent found a clear answer.
Old 08-24-2008, 10:24 PM
You could use the mmc/encoders/###/encoder_merit properties to set up tuner priority, but that won't guarantee that the higher merit tuenr is always used for a certain channel.
Personally, if a channel can't be trusted to record properly from a tuner, I wouldn't enable it on that tuner.
Old 08-25-2008, 02:16 PM
I was thinking this was the only way - but I kept hoping... oh well I need to wait on my hdpvr to get returned anyways
Thanks Andy
Old 10-31-2008, 02:33 AM
mskitty666 mskitty666 is offline
Andy, please explain this too me. I went through the trouble to assign tuner merit and recording directories and they seemed to work perfectly until recently. I was infuriated that SageTV is ignoring my specifications and just doing whatever the heck it wants! I thought these properties were there to tell SageTV what to do but it's not listening.
Old 10-31-2008, 02:51 AM
You've probably already found the answer, but in case you haven't, you need to search the forums for threads about channel mapping. I used the information to create six lineups for my four tuners. It involved setting up my atsc tuners to use a very nearby lineup with the same channels available in my city then I remapped the logical number to be near the SD channel in the guide. For my cable box I used the digital cable lineup and deselected all analog channels. For basic cable I used the basic cable lineup deselecting any channel that I don't actually get.
The result, lets use CBS as an example. In my guide I see 6, then 6-1 HD, then 6-2 DT. When the digital tuner is recording a show on CBS I see it marked on 6-1. When it records analog it is marked on 6. It never uses the cable box to record CBS because I have disabled it in the digital lineup. Is this what you're trying to accomplish?
Tell which tuner made a recording? wirecreative Hardware Support 6 03-13-2008 04:32 PM
Lost tuner functionality? pjpjpjpj SageTV Software 4 03-07-2008 12:17 PM
Plugin to seek/jump to specific time in recording? LehighBri SageTV Customizations 4 07-31-2007 02:59 AM
limiting HD recordings to specific tuner? dfitz43 SageTV Software 3 09-25-2006 11:30 AM
Recording Conflict Won't Clear TheraEdge SageTV Beta Test Software 7 01-10-2006 08:06 PM
