Old 11-13-2008, 03:13 PM
craigap craigap is offline
HD100 video output gives Green Screen whenever I turn the switch on in back
Whenever the power goes out or I have to reset the box by turing the switch on the back off then on, I get a green screen for output. I can fix it by pressing the video out button, but its getting annoying. Is there a fix for this? I'm using HDMI. When setting up the HDMI it have tried a number of combinations for supported resolutions. my TV supports up to 1080i, and I've had all but the 1080p one selected.
Old 11-14-2008, 06:08 AM
I would try turning off 1080i in your options and see if that fixes your problem. See if 720P only works.
HD100 as a video switch? jptaz SageTV Media Extender 1 03-01-2008 09:40 PM
Video playlist in default STV - exits playback screen between videos cncb SageTV Studio 2 01-09-2008 02:56 PM
SageTV V6.3.2 Beta is Available! Narflex SageTV Beta Test Software 0 11-21-2007 07:08 PM
Green Screen (New Install) BigRig64 SageTV Software 3 12-30-2006 03:15 PM
