Old 04-07-2009, 08:33 AM
agover agover is offline
close captioning always active since firmware update
Hey There,
Has anyone encountered a corrupted closed captioning line always on screen during video playback since the last firmware update (403)?
Any ideas how to get rid of it?
Adam
Old 04-07-2009, 08:39 AM
HelenWeathers's Avatar
Originally Posted by agover View Post
Hey There,
Adam
You either have to install SageTV 6.5.13 beta or roll back your firmware to the prior beta (20090316 I think).
See this thread:
http://forums.freytechnologies.com/f...ad.php?t=40928
Old 04-07-2009, 08:51 AM
If you decide to roll back your HD200s firmware to 20090316 download this:
http://download.sage.tv/firmware/stp200-20090316-0.bin
Rename the bin file to stp200.bin, place it in your Sage server's program files\sagetv\sagetv folder and follow the instructions here:
http://forums.freytechnologies.com/f...7&postcount=16
Can't update firmware lmeyer SageTV HD Theater - Media Player 2 01-02-2009 04:58 PM
Problems with Close Captioning.... Chaos~Theory SageTV Software 1 12-11-2008 06:01 AM
Closed Captioning Update? mets3145 SageTV Software 48 03-12-2007 01:58 PM
