Old 07-02-2004, 11:35 AM
srothwell's Avatar
srothwell srothwell is offline
Turn off De-Interlacing
How can I completely turn off any de-interlacing from Sage?
Using the defaults in the setup menu, when I playback to a TV set (through my ATI 9500), the field order has been revered and it's unwatchable.
Old 07-02-2004, 11:39 AM
mlbdude's Avatar
mlbdude mlbdude is offline
If you disable deinterlacing the video will not be properly displayed on your PC or TV. Only a Matrox can output properly this way.
If you still want to, just like in any PVR you need to do it in the decoder. Any settings you make in the PVR app will be ignored.
Old 07-02-2004, 11:43 AM
srothwell's Avatar
I guess a better question would be....
How do I get the field order correct on the output to my TV?
It looks like field 1 and field 2 are reversed, which obviously makes everything jerky.
When I use Snapstream's Beyond TV it outputs great... no problems, but SageTV is reversing the fields.
It's not the encoding process becuase I took the MPEG files from a recorded show and put them right to DVD and it plays fine on a set-top DVD player into a TV.
Any help would be greatly appreciated!
Old 07-02-2004, 11:47 AM
mlbdude's Avatar
Check my reply in the other thread.
Old 07-02-2004, 01:18 PM
you can flash the video card bios to get output from an nvidia card like a Matrox
