Old 03-06-2017, 06:26 AM
willieb willieb is offline
Need help with OpenDCT on Docker
Can someone please help me with installing OpenDCT in my Docker?
I tried the CraziFuzzy version as found in other threads, but I got the following error:
root@localhost:# /usr/local/emhttp/plugins/dynamix.docker.manager/scripts/docker run -d --name="OpenDCT" --net="bridge" -e TZ="America/New_York" -e HOST_OS="unRAID" https://github.com/CraziFuzzy/opendct-docker
/usr/bin/docker: Error parsing reference: "https://github.com/CraziFuzzy/opendct-docker" is not a valid repository/tag.
See '/usr/bin/docker run --help'.
The command failed.
Can someone point me in the right direction or tell me what other information you need to help me? Thanks.
Old 03-06-2017, 07:30 AM
Where are you putting that URL?
Old 03-06-2017, 08:02 AM
Probably the wrong place!
I am not in front of my machine right now (I'm on my way to work), but I was putting it in the repository field of the Docker "Add Container" page.
I was going from something you said in a different thread:
I did push out a new image today. I honestly have never posted it to CA, because I never got around to figuring out how that's done. I just add
https://github.com/crazifuzzy/opendct-docker
into unraid's docker page.
Where should I be putting it? Thanks for the help!
Old 03-06-2017, 08:41 AM
It should be placed as it's own line in the Template Repositories textbox on the Docker screen. Then click SAVE. Once that's done, you should be able to add a container, and the crazifuzzy/opendct should be an option in the Template pulldown.
Old 03-06-2017, 09:27 AM
OK -- Will give it a shot. Thanks for the guidance. Much appreciated.
Old 03-07-2017, 07:36 AM
Just wanted to report back. As I mentioned here, I got everything working last night. I ultimately had to remove all of my containers and start over. Wherever I pasted that URL had screwed something up. After I did that, I had some trouble finding my HDHR, but figured out my issue from the thread linked to above. Thanks again Fuzzy. Hoping to move over to UnRAID on my production system in a week or so. It is nice seeing 3GB of RAM available in my JVM heap.
OpenDCT on Docker not finding HDHR BobbyDing SageTV for unRAID/Docker 43 03-28-2017 06:40 AM
opendct location mechling-burgh SageTV for unRAID/Docker 2 02-04-2017 08:37 PM
problem tuning single channel with OpenDCT Docker matt91 SageTV for unRAID/Docker 1 01-25-2017 01:58 PM
Broke my OpenDCT? ThePaladinTech Hardware Support 2 03-29-2016 03:19 PM
OpenDCT: Can I use it? SDeGonge Hardware Support 7 02-20-2016 10:27 AM
