Old 03-01-2009, 11:58 AM
ace007 ace007 is offline
How to Reset HD200 back to Factory Defaults for Remote
In trying to get my HD200 to work well with my Harmony remote I have it all screwy and its hard navigating the menus even in the standalone UI with the factory remote. Looking for a way to get every reset back.
Robert
Old 03-01-2009, 12:01 PM
QueOnda's Avatar
QueOnda QueOnda is offline
Do a search but I believe you disconnect the HD200 then when you plug it back in push the delete button on the remote until you see some blinking.
I've had issues with my harmony remote (890). I had when I push the button once it would want to move 2 to 3 times. I had to contact support to fix.
Server: HP AMD64 dual core running Win7 64bit (MCE disabled) with 4G memory Tuners: 2 PVR-500(disabled), 3 HDHR and 1 HDPVR Clients: 2 HD200 and 1 HD100 TV: 70" and 52" and 42" Media Storage: ReadyNas 8TB Recording media: 300GB + 200GB+ 250 GB Network: Gigabit backbone'
Thanks to all the developers who work on SageMC, code, utilities and plug-ins to make SageTV better!!!
Old 03-01-2009, 12:06 PM
ok.. so I found the instructions and ran the reset to get the remote fully functional in the Standalone UI. I'm still however getting some wierdness once I connect to the Sage server. For example if I go to the guide I can use the number keys to key in a channel number but I have to hit each number twice for it to show up. If I'm watching live TV and I try to key in a number the numbers act as navigation buttons and try to skip the recording around. Any ideas?
Old 03-01-2009, 01:31 PM
QueOnda's Avatar
What issues are you having setting up your remote? The HD200 remote codes are setup in their devices.
If you are having issues, contact Harmony support. That's the only way mine were fixed.
Old 03-01-2009, 02:04 PM
Having the same issues with the original HD200 remote. The main issue I have left is manu buttons including the numbers requiring two presses to get them to show up on screen and the number buttons acting as navigation buttons while playing video.
Anyone else having to reset the HD200 bigbill SageTV Media Extender 33 12-29-2008 10:39 AM
Help..how do I reset back to start garyellis SageTV Media Extender 7 12-21-2007 06:11 AM
I would like to reset all SageTV 4.0 registry settings back to the original defaults mkanet SageTV Software 3 11-14-2005 07:03 PM
People using Girder remote defaults Crowdx42 Hardware Support 0 03-16-2004 05:51 PM
Factory defaults? jphhughes SageTV Software 0 01-27-2004 06:15 PM
