Old 07-10-2012, 08:37 AM
tp9163 tp9163 is offline
Send a message via ICQ to tp9163
Exclamation Some airings of one of my 'favorites' isn't being scheduled
http://i47.tinypic.com/333l744.jpg
http://i48.tinypic.com/35a6c0x.jpg
As you can see from the screenshots, the following aren't being scheduled:
7/10 Tue - both episodes
7/11 Wed - both episodes
7/13 Fri - 1st episode only
7/17 Tue - both episodes
7/18 Wed - both episodes
7/20 Fri - 1st episode only
What is it about Tuesdays, Wednesdays, and also 1st episode's of Fridays that it's not wanting to schedule them??
1. And yes, I do have it set to record both First Runs and ReRuns.
2. Malore options is turned off.
3. I've already tried to remove/re-add this favorite.
4. I've deleted *.properties to start fresh.
5. Recording Schedule confirms the airing schedule as shown above.
Old 07-10-2012, 11:59 AM
Slugger Slugger is offline
Sage believes you've already got that episode recorded or it's scheduled to record at another time. Look at the episode id for each not scheduled to record, I suspect they're similar to ones scheduled to record or already recorded.
Twitter: @ddb_db
Capture: 2 x Colossus
STB Controller: 1 x USB-UIRT
Old 07-10-2012, 02:57 PM
How would Sage even know whether I have those eps or not, if I had used a 3rd party program to convert them to mp4?
Well, either way, I 'fixed' it.
I went and deleted wiz.bin (but not before backing it up)
then opened Sage, saw it was now scheduling them properly
exited Sage, replaced wiz.bin with my original one
It now is STILL working fine, even after replacing the original wiz.bin back. How did that happen?
Old 07-10-2012, 03:37 PM
evilpenguin's Avatar
You can force Sage to forget which shows you watched in the advanced options under a favorite. I have to do this every few months with my syndicated shows otherwise it stops recording them when they loop back around and start re-airing.
Clients: 1xHD200 Connected to 50" TH-50PZ750U Plasma
Server : Shuttle SFF SSH55J2 w/ Win7 Home, SageTV v7, Core i3 540, 2GB RAM, 30GB SSD for OS, 1.5TB+2x1TB WDGP for Recordings, BluRay, 2xHDHR, 1xFirewire
SageTV : PlayOn, SJQ, MediaShrink, Comskip, Jetty, Web Client, BMT
Having a problem? Don't forget to include a log! (Instructions for: PlayOn For SageTV v1.5, MediaShrink)
Old 07-18-2012, 07:37 AM
UgaData's Avatar
UgaData UgaData is offline
I too have recently experienced Favorites not being flagged for recording.
a few weeks ago it was an episode of Eureka. I recorded it by setting up a manual recording (for just that one episode, all others have been flagged just fine)
And now the upcoming season opener for Warehouse 13 is not being flagged to be recorded. Looking at the show in the guide it is definitely a new first run show. The favorite for Alphas is set to record. (Seeing Alphas in the recording schedule and not Warehouse 13 is what led me to look into this further.)
Curious that in my case both times it has been a SyFy channel show.
Old 08-21-2012, 09:34 PM
TechBill's Avatar
TechBill TechBill is offline
I have the exact same issue ...
I missed last season show of Warehouse because SageTV deicded not to recording it like it thought it already had recorded it so when I saw it gonna be a re-run again this season. It got skipped over again ...
uuuuuuuuugggggggggghhhhhhhhhhhh!!!!!!!!!!!
I should had manually set the record!
Still why did it skipped those favorite when it not been watched or not in conflict with other recording
sigh ......
Bill
HTPC System
Media Extenders
HD300
HTPC Software
Old 08-22-2012, 07:20 AM
Taddeusz Taddeusz is offline
sigh ......
Bill
I've found there can be a couple reasons for this. One of them is a recording conflict and it sees that there is a later airing that it can record instead. Another one that I've seen with troubling frequency lately is that the HD flagging in the EPG is not correct for the initial airings but a later airing has the HD flag properly set. This situation causes SageTV to prefer the airings with the HD flag set properly and ignore the initial airings even if the channel is an HD one. In fact, I believe I've had this happen with Warehouse 13 and other SyFy shows lately. Sometimes I'm quick enough to catch it. Other times not and we have to wait a week. It's not a huge deal, just a bit of an inconvenience at times. We're behind on most of our shows so it really doesn't become too much of an issue.
Old 08-22-2012, 07:46 AM
mechling-burgh mechling-burgh is online now
I had a problem similar to this when I moved to windows 7 and copied over the wiz.bin file. The shows would show up in the to be recorded que but not record till a later airing. I ended up deleting all my favorites and reentering them. This did solve my problem but was a pain to input all my favorites again. I got the web server to print out my favorites list before I deleted them all.
Scheduled Recordings Only Showing Today's Favorites edmc SageTV Software 2 07-19-2010 09:22 AM
Setting favorites to only record HD airings DavidFeinzeig SageTV Software 6 06-03-2009 07:33 AM
Favorites Not Scheduled jcesare SageTV Software 1 06-14-2007 09:02 PM
Favorites being re-scheduled... AngelofDeth SageTV Software 3 03-15-2007 08:05 PM
Scheduled Recordings and Favorites Gone jorowi SageTV Software 7 07-07-2006 10:38 AM
