Lost Power When Upgrading Firmware On HD-100
Is there hope for me?
Have already submitted a support request but thought you may be able to help. I lost power when upgrading the firmware on my HD-100 (Long story do not ask). Tried to recover the unit by the Configuration Reset Procedure nothing. Downloaded the bin file, and followed the Recovery Procedure, but nothing. The HD-100 sits there with the Active light on and the link light flashes every 5-6 seconds. Just wanted to know has anyone ever managed to recover the unit once this has happened (I can not be the only stupid person that done this, can I) Dean, |
_Demo_ |
I had a power-loss "issue" a while back and the recovery procedure worked perfectly.
SageTV V7 (WHS), Diamond UI Server: WHS with Xeon X3350, 4GB ECC, ASUS P5BV-C/4L, recording into a 6.6TB Drive pool Tuners: 4 (2x HDHR) Clients: 2x HD300, 1x HD200 Extenders, 1x Placeshifter 2x Roku XD |
Thanks for your replys
I have my HD100 connected to a router that is also my DHCP Server. Can you tell me how the HD100 connects to the Sage Server when you run the recovery process is it by IP or a broadcast on the MAC address. The reason I ask is I was going to try with a across over cable to by pass the router. Would this work? Or do I have to set up some static IP address on the server. Dean |
_Demo_ |
Finally fixed my problem.
![]() Thanks for your help on this. It turned out to be my router. It would assign an IP address to the HD100 but was not able to see the server and you could not ping its IP address. I installed Tiny DHCP Server on my Sage server and plugged in the HD100 by cross over and it worked. Dean. |
Bad timing - power outage during firmware update | Texsun | SageTV HD Theater - Media Player | 3 | 04-20-2009 06:13 PM |
No audio on HD-100 after firmware update | rm1759 | SageTV Media Extender | 2 | 01-26-2009 10:04 PM |
Revert back to old firmware on HD-100 | rdefino | SageTV Media Extender | 19 | 01-12-2009 03:32 PM |
20080125-2 Firmware Problem - Can't Power On | bialio | SageTV Media Extender | 7 | 01-30-2008 10:16 AM |
