Old 08-14-2003, 10:32 AM
malore's Avatar
malore malore is offline
Pointer visible during show playback
Anyone else have troubles with the mouse pointer staying visible during playback. I usually just move it to the corner so it's offscreen., but I was wondering if this is a common problem or not.
Old 08-14-2003, 10:51 AM
fidget's Avatar
fidget fidget is offline
Re: Pointer visible during show playback
I find that pressing the <ALT> key can cause it to be rehidden (it may take two presses). This is a "Feature" of Windows (it gets confused at times) and the <ALT> key will put the cursor in the menu (which SageTV does not have) and the put it back (hopefully to the hidden state).
Old 08-14-2003, 11:02 AM
malore's Avatar
Thanks, I'll try that. Glad to hear I'm not the only one.
My thought was that SageTV could just automatically move the pointer to the bottom right hand corner when the pointer should be invisible.
Old 10-23-2004, 08:50 AM
My cursor stays on the screen even during the Sage screen saver. I have to put it into the lower corners to hide it.
Old 10-23-2004, 09:15 AM
mls mls is offline
This situation appears to happen when something else steals focus. I just click in the middle of the SageTV screen (when it's running full screen) so SageTV is back in focus and then the mouse pointer goes away after a few seconds (as it should be doing always otherwise).
Old 10-23-2004, 09:29 AM
dvsing's Avatar
dvsing dvsing is offline
Send a message via AIM to dvsing
I've had this problem show itself once in the past week or so... I had never seen it before. I'm not sure what caused it and I didn't try and of the aforementioned solutions.
Old 10-23-2004, 09:33 AM
JasonJoel JasonJoel is offline
Yup, happens to me all the time lately.
I move it off the screen, too.
SOMETIMES clicking on the Sage window will make it go away, sometimes it doesn't though.
Jason
Old 10-23-2004, 10:10 AM
ukmgranger's Avatar
ukmgranger ukmgranger is offline
I have an app called movemouse.exe that puts the mouse in the bottom right hand corner.
This can be set to run on startup.
I'm not sure how I can put the app on the forum.
I think (can't quite remember) I got it from HTPC news.
Old 10-23-2004, 11:02 PM
I've just noticed that animated cursors really cause a problem here. Apparently the animation grabs the focus, and it won't stop showing the cursor.
Old 10-24-2004, 06:40 PM
jklenk jklenk is offline
This always happens to me. I have to move the mouse to the bottom of the screen. It's a bug in SageTV, IMHO. They should make it like TheaterTek, where the mouse disappears after a few seconds timeout.
Old 10-25-2004, 09:51 AM
cassis6 cassis6 is offline
On my system, when the cursor is still on when viewing a recording, I usually press the Information button. When the display automatically times out, the cursor gets hidden as well.
