Old 03-02-2009, 12:35 PM
williamc9341 williamc9341 is offline
Remove/stop/cancel daily recurring timed recording
How do I get rid of a daily recurring timed recording? I select it in the recording schedule and select "stop," it disappears for a moment, but (I assume due to the 'recurring' aspect) it simply reinstates itself, forever and ever. I imagine it would be gone if a 'one-time' timed recording, but it seems for recurring recording, we're stuck in a loop that can never be escaped. There appears no way to kill it. I want to stop the daily action, not just one time. All of them, at that selected time each day. Forget I ever asked to record the time slot each day. Any answers???
Old 03-02-2009, 11:59 PM
barretto barretto is offline
I have the same problem. I was trying to set up a 7 minute recurring recording for just the remainder of this week (tue, wed, thur, and friday). But now, Sage wants to record the same 7 minutes on those four days, forever. I can't seem to cancel the recording.
Any ideas?
Old 03-03-2009, 02:06 PM
Razillian's Avatar
Razillian Razillian is offline
From the manual (read the stuff after as well):
Canceling a Timed Recording
To cancel a timed recording, go to the Recording Schedule and select one of the entries for the
timed recording (or the only one, if it doesn’t recur). On the Program Information screen, select
Record Options. In the resultant pop-up, select Cancel Recording.
But I just tried (created a timed recurring recording for every day from 5-6PM) and canceling does not work. I would have to guess that it is a bug. I'll be submitting a bug report on it and I would suggest others do the same.
blog: www.iamwhen.com
Old 03-03-2009, 09:40 PM
I've already submitted a bug for it and received a reply. Basically the problem is with the upcoming time change. This week was the only week that you would run into the problem. (Figures this would be the one week I've ever tried to use a recurring timed recording. lol)
Anyhow. The issue will work itself out next week. The real problem will be fixed in a future release of SageTV.
Cheers,
//Robert
daily, recording, recurring, remove, stop
Daily Timed Recording conflicts with self, eats cpu, corrupts db - possible ? Gaurav SageTV Software 13 10-27-2006 07:30 AM
Recurring recording based on time/channel? kelemvor SageTV Software 3 10-05-2005 09:31 AM
Remove repeating 'timed recording' snoopy SageTV Software 4 07-18-2005 09:18 PM
Can't stop Timed Recording, HELP. SteveP SageTV Software 3 02-14-2005 07:21 PM
Recurring Time-Based Recording Bugs? spacegoat SageTV Beta Test Software 5 05-01-2004 04:42 PM
