Hi folks, quickly installed v7 just now - both the Server and the Placeshifter.
Upon opening the Placeshifter, the skin is the default v6 UI. What am I missing in order to get the new UI working? ![]() Thanks!
Al Bsharah / Twitter Clients: Two STX-HD100 High-Def Extenders Media Server / NAS: Case: Thermaltake Armor CPU: AMD Opteron 1218 (2.6GHz Dual Core) Motherboard: ASUS MN2-LR Memory: 2GB Gfx Card: Headless Tuner: Hauppauge HD-PVR, Hauppauge PVR-350 (not in use) O/S: Windows 7 Sage: Latest RAID: On-Board Drives: 6 x 1.5TB SATA RAID-5, 2 x 80GB IDE RAID-1 (O/S) Storage: 7.5TB Total |
Please use the beta forum when posting about a beta version, unless you are posting about a customization; this thread has been moved.
See this post in the "How to install..." thread. Placeshifter & extender clients do not automatically revert their STV after an upgrade. - Andy
Just go into setup(through the placeshifter) and change the stv to sagetv7.xml.
Windows 10 64bit - Server: C2D, 6Gb RAM, 1xSamsung 840 Pro 128Gb, Seagate Archive HD 8TB - 2 x WD Green 1TB HDs for Recordings, PVR-USB2,Cinergy 2400i DVB-T, 2xTT DVB-S2 tuners, FireDTV S2 3 x HD300s |
Ah!
1) Apologies for posting in the wrong froum 2) I had attempted to change the theme, but the new XML file wasn't listed 3) Clicking "Revert" did the trick...I didn't see that last time around. Thanks! Working like a charm...
If you are manually traversing the folder paths in the file browser dialog in SageTV to load an STV, as opposed to using "revert", then you'll need to go to the correct folder for the SageTV3 and SageTV7 STVs. - Andy
New Theme for Linux?
I feel a bit crazy here, and am probably missing something simple, but I don't have the new Sage 7 theme? I upgraded my Sage linux version to 7.0.9.1 (as reported in Help > System Information) and connect to it with my HD200 (with upgraded beta firmware) and everything looks exactly the same at version 6?
I also curiously don't have the plug-in manager in Setup > SageTV Plugin as reported in the release notes? * merged; see above * |
Tags |
placeshifter, user interface, version 7 |
SageTV installed and few problems | getstarted | SageTV Software | 10 | 08-11-2008 12:27 AM |
Bought PlaceShifter, installed - says trial? | avonnied | SageTV Placeshifter | 3 | 06-20-2006 07:39 PM |
Installed V4 - Why does SageTV still say it's V3??? | Ctrl-Z | SageTV Software | 2 | 11-02-2005 06:33 PM |
Can SageTV and SageRecorder be installed on the same computer? | boomstick | SageTV Software | 1 | 06-11-2004 11:12 AM |
