Hundreds of Error in MediaServerConnection of :java.io.EOFException
I was trying to investigate why the playback of many HD recording seems to pause/freeze for 5-10 seconds sometimes. I enabled debug logging. I sees hundreds of entries similar to Error in MediaServerConnection of :java.io.EOFException in the log. I am not sure what these are. I could find any mention of it previously. Any ideas?
I realize that this may not have anything to do with my freeze problem, but I still want to find out. BTW, I uninstalled all plugins except webui. I am running 7.1.5 beta on Win 7. Log file attached Thanks Sarat |
you are getting alot of
Sat 3/26 23:04:49.495 [BGLoader2-001d6a5caab4@f62a93] Loading 0x0 image from file C:\Program Files\SageTV\SageTV\GeneratedThumbnails\fSageRecCitySlickersIITheLegendofCurlysGold64682690mpg.jpg Sat 3/26 23:04:50.447 [MediaServerConnection@491681] Error in MediaServerConnection of :java.io.EOFException Sat 3/26 23:04:52.947 [MediaServerConnection@491681] Error in MediaServerConnection of :java.io.EOFException Sat 3/26 23:04:52.962 [MediaServerConnection@491681] Error in MediaServerConnection of :java.io.EOFException Sat 3/26 23:04:55.503 [MediaServerConnection@491681] Error in MediaServerConnection of :java.io.EOFException which is an end of file exception. Basically its trying to read a size 0 file and going past its end. Looks like alot of your images might be corrupt. (it wasnt just this thumbnail, it was your tvbackground as well).
Gigabyte GA-MA770-DS3/4gb DDR2/AMD Phenom 955 3.2ghz Quad Core Windows 7 64bit Home Premium Hauppauge 1600/1850/2250/colossus/2650(CableCard 2 tuner) 8tb RAID5 storage/media/other &3tb RAID5 backup storage on a HighPoint RocketRaid 2680 1tb 3 disk Recording Pool all in a beautiful Antec 1200 SageMyMovies/Comskip/PlayON/SageDCT/SRE HD100/HD300 extenders |
Thanks Sarat |
i only said that because
Loading 0x0 image means image dimensions. I would bug it with sage beta program and make sure to attach the image file as well, i dont think you are the only one have jpeg problems.
Solved
Never mind. My error. I forgot about the small acer rivo setting in home theater closet that still has 6.6 client on it. I haven't used that thing in a while and completely forgot about it. When I upgraded to Sage 7, I used the same IP for server. It appears that this error occurs when the 6.6 client tries to connect to a Sage 7 server.
Thanks Sarat |
Java error: java.lang.NullPointerException | neil.prasad | SageTV Software | 8 | 12-13-2011 07:43 PM |
Getting Hundreds of error from [Fork-JREkiwi-1705803@1072a3a] | pjwerdna | SageTV v7 Customizations | 10 | 04-06-2011 05:10 PM |
Java Error! Please help | cash | SageTV Software | 17 | 03-04-2011 09:44 PM |
Error in MediaServerConnection of :java.io.EOFException?? | phelme | SageTV Software | 1 | 01-05-2009 11:05 PM |
SageTV Client java.io.EOFException | Coolwave | SageTV Beta Test Software | 2 | 01-26-2004 10:40 AM |
