successful upgrade
Been holding off on my ver 9 upgrade.... dont know why I waited. the only trouble I had with the entire thing was not rebooting my server after I put the old server key in. the system is way faster then ver 7, and my hd100 and 200 boxes never wait between remote clicks. I also upped the java heap that was set to 0, so it looks like I'll not have to do a computer upgrade like I was planning this winter.
This is definitely a 2 thumbs up upgrade |
Can i install v9 and then copy the wizbin and properties file from my v6 server and have everything work OK?
I'd like to do a clean install of V9 and not the upgrade from v6 to v9 which contains a lot of legacy junk but maintain my settings and TV show files.
- James M - Server: Asus P5B Deluxe, 8GB, Core2 E6600 @2.4GHz, Windows 10 X64 Pro Storage Internal: (1) 250GB, (2) 2TB, (1) 4TB Storage External: Sans Digital 4-Bay eSATA Port Multiplier RAID Enclosure with (4) 4TB Drives Capture Devices: HDHomerunXTEND, HDHomerunPrime Clients: (1) STX-HD100 HD Media Extender, (3) HD200 HD Theatre, (1) HD300 |
I would like to know this also.
i haven't gotten any responses about upgrade. maybe no one does it or v9 isn't being used much? Guess i'll have to experiment myself. The upgrade to v9 on top of V6 worked fine. I think there are added entries in the sage.properties file so you can't just replace it with the v6 version. There are a lot of files in the SageTV directory tree and I don't know what most of them are for.
I've never done the upgrade from v6 to v9, I used to have v7, but have not upgraded the "family" system, only my test systems.
If you list the one's you have questions, I can try and help with what I think I know... ![]() |
I've only done v7 to v9. I've done/ attempted 2 so far. I did mine no problem. I worked on a friends system and we had to roll it back to v7. It might have been an easy fix but we were out of time and just rolled back to the snapshot we took before. (both our sage servers are virtual - mine hyperv, his vmware)
(current) SageServer: SageTV Open Source V9 - Virtual Ubuntu on Win10 HyperV MSI 970A-G46, AMD FX-8370 , SD Prime via OpenDCT, Donater ComSkip Clients: HD-200, Nexus Player w/ Android miniclient Storage: "nas" 16 drive Win10 w/ DrivePool running Plex, Emby, & SD PVR Retired - Hava, MediaMVP, HD-100, HD-PVR, HVR-2250, Ceton InfiniTV4, Original (white) HDHomeRun Died - HD-100, HD-300 |
I always recommend the reverse. Upgrade in place (after a backup) OR copy v6/v7 to a new location and install over it. Maintaining settings only from a previous install is a difficult and risky task at best. I chose to do a fresh install but then spent a pile of time setting things up the way I wanted it again....my Gemstone settings were exported and then imported but a number of other items had to be setup manually once I recalled what I was missing ![]() Perhaps someday an export/import for SageTV in general will be on my todo list but that list is pretty long ![]() k
If you wish to see what I am up to and support my efforts visit my Patreon page |
But how do i maintain all the recorded show descriptions, favorites, etc with a fresh install? I'm ok with resetting up various things but i can't lose all the program data. Will just copying the v6 wiz.bin be OK?
Just copying over the Wiz.bin wil do ... it contains all the data.
Windows 10 I3 Dual Core 3.0 Server, SageTV9... OpenDCT with 2 HDHRPrimes and 4 HDHRconnects for a total of 14 Tuners. |
You need to copy wiz.bin over while Sage (and the sage service) are stopped/exited. The first time you launch sage after that, it will see the old Wiz.bin and it will upgrade it to the new format. Sage has made some changes to the format of wiz.bin over the years. They have always been good about making sure new versions of Sage can read the old versions of wiz.bin, but once you do, you usually can't go back (you can't take a wiz.bin that has been used with v9 and use it in v6). So make sure to keep a backup copy somewhere else outside of the Sage folder in case you ever need to go back.
Is there a step by step somewhere for a clean install of V9?
This space intentionally left blank |
So far: my Sage experiment has been mostly successful | SomeWhatLost | SageTV Software | 1 | 01-18-2009 10:25 PM |
Successful Hardware Combinations | Radioguy | Hardware Support | 1 | 04-10-2008 09:32 PM |
Successful BTV to Sage Conversion | deipert | SageTV Software | 7 | 01-19-2008 09:15 PM |
Harddrive move successful!! | jominor | SageTV Software | 19 | 07-23-2007 02:15 PM |
Rotating pictures - anyone successful ? | dflachbart | SageTV Beta Test Software | 2 | 10-14-2006 07:43 AM |
