Old 12-15-2020, 05:56 PM
timg11's Avatar
timg11 timg11 is offline
New SageTV Server Build - HDHR "No Signal"
I'm working on building a new SageTV system with 64 bit Windows 10.
I have a HDHR Quattro. Because the 32 bit SageTV system is still active and in use, I removed the fourth tuner (Tuner3) as a source from the existing SageTV system, and added it the only source on the new system.
From the new system, I can use the SiliconDust Config GUI to access the tuner, and it can tune and display channels from the new computer system and the video looks normal.
The Source setup works as expected in SageTV for the HDHR tuner 3. The lineup is correct, and the Schedules Direct Schedules are working. However, when tuning a channel (preview from Source, or from Program Guide), I get "No Signal".
What should I look at first?
HD300 extender with (2020 New Build) SageTV 64 bit V9.2.2.903 (service mode), Running on Windows 10 (64 bit), Intel Core i7-10700K CPU, 16G RAM, GIGABYTE Z490 UD motherboard. NVidia GTX1650 Super; Viewsonic LCD on one output and Mitsubishi WD57734 HDTV via DVI/HDMI on other output. HDHomeRun HDHR5-4US tuner, Hauppauge "Siena" 1512 HD-PVR2 connected to Cisco Cable modem from Spectrum, tuned with USB-UIRT.
Old 12-15-2020, 07:27 PM
CptKirk CptKirk is offline
From the 9.2.2 known issue list
HDHR fresh installs will not find the 64 bit install. 2 work arounds....
  • Install the 32 bit version somewhere else, configure HDHR first time, and then you could uninstall the 32 bit version
  • Try selecting JRiver Media Center, BeyondTV or Other: ATSC/QAM in the HDHR configuration
9.2.2 Windows Installer
SageTV running on: Win10 21H2
SageTV 9.2.6.976 (64 bit)
Java 1.8.0 311 (64 bit)
OpenDCT 0.5.32 (64 bit)
Clients: HD300 (x2)
HDHR3-CC Prime 20220203 (Comcast CableCard) - 3 Tuners
HDFX-4K Flex 20220203 (OTA) - 4 Tuners
Old 12-16-2020, 07:34 AM
timg11's Avatar
I forgot to mention that I did install both 32 bit and 64 bit SageTV, and I get the same results with both.
I will try "selecting JRiver Media Center, BeyondTV or Other: ATSC/QAM in the HDHR configuration"
Old 12-16-2020, 09:48 AM
JustFred JustFred is online now
Was a "Scan For Available Channels" performed in Sage's Channel Setup screen?
Old 12-17-2020, 07:34 AM
timg11's Avatar
A channel scan finds zero channels when run from the 32 bit version of SageTV on the new computer.
In HDHomeRun Setup / Configuration there is a setting for BDA Compatibility Mode, which is set to "SageTV". I do not find any options for "JRiver Media Center, BeyondTV or Other"
Since I have a working SageTV 32 bit on another machine, are there some configuration setting files I should review and compare?
Old 12-17-2020, 01:32 PM
Have a look at the detailed instructions here:
https://sagetv.fandom.com/wiki/Appen...p_Instructions
Old 12-19-2020, 06:01 PM
timg11's Avatar
Thanks for the pointer to the detailed instructions.
I followed them exactly, and everything now works properly from the HDHR setup.
I think I missed the step of running the scan in the HDHR setup, since the channels were already visible in the lineup in SageTV.
hdhr
"Moving" an HDHR from one Sage Server to another wayner Hardware Support 4 12-09-2010 11:47 AM
"No Signal" & "Halt Detected" errors puulima Hardware Support 5 07-07-2010 11:19 AM
"No Signal" from comcast into HDHR and cannot start playback.. hufnagel SageTV Software 0 03-14-2010 10:49 AM
"No signal" in Windows 7 on almost all channels (HDHR OTA/QAM, etc.) gtd885a Hardware Support 24 07-09-2009 10:49 AM
Stutter/Jitter using A180/Vbox and OTA? Check signal "Strength" not "quality" svemuri Hardware Support 0 12-13-2005 10:51 AM
