After 15 years, my network encoder PC's drive has died.
![]() But a lot of people are running two HD-PVR's on one system, right? The IP tuning helps a lot so that won't be an issue. I've heard people talk about the "unique ID" as a way to tell the two encoders apart which I've never had to worry about. is that a USB thing? |
I have been running two HDPVR 1212s on the same computer for many years now. No problems. I believe there is a unique ID somewhere, but I have never bothered looking into it too closely. As long as you keep each one plugged into the same USB port and connected to the same Directv receivers (and keep the receivers as static IP addresses for tuning), you shouldn't have any issues.
I have a dedicated HD-PVR network encoder that houses three HD-PVRs, that feed two servers. As Evil_Attorney mentioned, assigning static IPs to the DirecTV boxes makes it easy to control and direct encoding. My 3 HD-PVR encoder is actually flawlessly running XP ...
I've already got the DirecTV boxes on static IPs so that's ready to go. OK I'll try to keep the HD-PVRs plugged in to the same ports.
Do I need to open up the 2nd HD-PVR in the Hauppauge software to get SageTV to recognize it and if so, does that software itemize all the HD-PVRs connected? |
I don't seem to remember ever needing to open the Hauppauge software at all to get the HDPVRs working, but perhaps I am forgetting. I just remember needing to install the driver and Sage was able to recognize everything after that.
Sage handles the numbering of the HD-PVRs, which can be good or bad. I assume you could go into the Sage.properties and change the sequence, but it's probably not that big an issue once you determine which device is being referenced. The blue ring light helps, in this regard. In my system they appear as "Hauppauge HDPVR", Hauppauge HDPVR #2, and "Hauppauge HDPVR #3 ...
thanks all! ![]() |
No, the spdif input has always captured DirecTV's Dolby Digital (AC3) output ...
anyway, I have both HD-PVR's on the server now. Only one receiver is using the Dolby Digital setting and the other I have disabled. that receiver was having audio sync issues whenever I enabled it (it has the gaming version of the HD-PVR, so they are not the same). maybe I'll update the Hauppauge driver software and try re-enabling DD on that receiver and see what happens. |
Sage client multiple instances across multiple desktops? | electronicsuk | Hardware Support | 5 | 05-19-2009 04:03 PM |
Multiple HD PVRs? Or any other multiple component video capture solution | supergerg | Hardware Support | 12 | 09-03-2008 06:52 PM |
Multiple tuners, multiple extenders watching live streams | tommymc | General Discussion | 4 | 07-03-2008 02:58 PM |
using multiple pvr150s to tune multiple external stbs | nick_l | Hardware Support | 3 | 03-13-2006 01:05 PM |
Multiple tuners, multiple playbacks in Video Dist. System | Red Baron | SageTV Software | 3 | 04-27-2005 06:39 AM |
