Old 10-23-2021, 05:29 PM
Evil_Attorney's Avatar
Evil_Attorney Evil_Attorney is offline
Directv IP Tuning on 64bit?
I tried installing the 64bit version this weekend but was unable to get Sage to recognize the DirecTVTuner.dll https://forums.sagetv.com/forums/showthread.php?p=476689&postcount=28. It was not showing up on the list of tuning options, no matter what I tried. Is this dll compatible with the 64bit version?
I also tried the alternate method of using the EXEMultiTunerPlugin was unable to get that approach to change any of the channels on my receivers.
Old 10-23-2021, 07:04 PM
wnjj wnjj is offline
Originally Posted by Evil_Attorney View Post
I tried installing the 64bit version this weekend but was unable to get Sage to recognize the DirecTVTuner.dll https://forums.sagetv.com/forums/sho...9&postcount=28. It was not showing up on the list of tuning options, no matter what I tried. Is this dll compatible with the 64bit version?
DLL’s are bit-specific so that one is definitely not compatible with 64-bit.
Have you tried Bob’s method outlined here? https://forums.sagetv.com/forums/sho...&postcount=183
You do not need the DLL from his .zip file since these instructions were from the 64-bit beta and the DLL is included in the released SageTV versions.
Finally, if you’d like to try it I did make a 64-bit version of that HTTP tune DLL but with code I built from scratch. It has not been tested by anyone but it’s here if you want to give it a try: https://www.dropbox.com/s/b7wnftvfkf...Tuner.dll?dl=0
Windows Installer
Old 10-24-2021, 10:29 AM
Thanks wnjj, your 64-bit DLL version worked perfectly! Incredibly helpful.
I did spend several hours yesterday trying to get Bob's method working and for some reasons could not get it tuning anything. The IR files were all named and contained the correct IP addresses. The BAT file also had the correct IP addresses. The registry had the correct setting, all the other required files were present, and no firewall issues, so I am not exactly sure what the problem was.
Old 10-24-2021, 10:35 AM
Well thatís great to hear.
One thing I forgot about EXEMulti that has tripped some people up: You need to make sure the registry key permissions are set to full access. The code requests R/W access even though it really only needs to read the key.
Windows Installer
Old 10-24-2021, 11:59 AM
I did a fresh install of Sage 64bit and the entry was there at install. Wouldn't that install the registry permissions properly? Or it there more to it? I did notice that when I added a dll or exe to the sage directory, Windows would add it as you would expect, but when you go to properties, it shows the file as being "blocked" because it was from another computer (I didn't realize Windows did that). But even then, I made sure all files were unblocked.
Old 10-24-2021, 02:05 PM
Iím not sure if the permissions are set up correctly by default but they could be. I was basing my comments on this response: https://forums.sagetv.com/forums/sho...3&postcount=39. Though his case was not involving the current installers or 64-bit.
Regardless Iím glad you have it working. I should probably consider adding these DLLís to the installer by default.
Windows Installer
Linux 64bit MiniClient (issues with JTux on 64bit) stuckless SageTV Github Development 23 08-19-2015 12:54 PM
Question about IP Tuning DirecTV freewheeling Hardware Support 14 04-19-2014 07:17 PM
What is DirecTV IP tuning? freewheeling Hardware Support 1 03-14-2014 06:02 AM
Serial Tuning DirecTv Steve52 Hardware Support 7 02-23-2012 02:16 PM
Tuning in a non-HD DirecTV channel on a H20 BFisher Hardware Support 2 05-22-2008 09:47 AM
