Replacing HDHomerun Prime
So my Prime looks like it bit the dust due to lightning last night.
I'm ordering a new one. I use OpenDCT with it. When I get the new one will I have to start from scratch with OpenDCT in regards to adding it as new hardware? Then creating new lineups in Sagetv? Or if I plug it in and give it the same IP address as the old one should everything just work? I'm really hoping for the last one.
SageTV running on: Win10 21H2 SageTV 9.2.6.976 (64 bit) Java 1.8.0 311 (64 bit) OpenDCT 0.5.32 (64 bit) Clients: HD300 (x2) HDHR3-CC Prime 20220203 (Comcast CableCard) - 3 Tuners HDFX-4K Flex 20220203 (OTA) - 4 Tuners |
I believe you'll have to call your cable company to pair the cable card with the new Prime. Then I would add the new tuner (via OpenDCT) using the same lineup as the old Prime in SageTV, and eventually delete the original non-functioning tuner.
The pairing is probably the most fluid process. |
HDHomeRun Prime 6 | mike1961 | Hardware Support | 12 | 02-21-2019 04:38 PM |
HD-PVR died, Replacing with HDHomeRun Prime | brianblank | Hardware Support | 7 | 10-26-2015 01:12 AM |
Need some help with HdHomeRun Prime | MarcusInMd | Hardware Support | 1 | 09-01-2015 03:52 PM |
Ceton and hdhomerun prime | CADDYROGER | Hardware Support | 2 | 08-24-2011 05:38 AM |
HDHomerun Prime? | cenwesi | Hardware Support | 26 | 04-19-2011 05:40 PM |
