Old 01-28-2011, 10:40 AM
burtonpark burtonpark is offline
HD 5450 How do I Setup Bitstream Audio
I am trying to setup an HD5450, and have downloaded the ATI CCC and enable bitstreaming in the ATI driver. However when I play a movie I get an Sage error "problem rendering audio".
Could someone else with a 5450 setup, advise how best to setup the CCC options and/or Sage codec options make it work well with Sage.
Clients:4xHD300, 1 HTPC Server: Case Lian Li B71 Hot swap, Supermicro X8 mobo, Xeon E5506 2.13Ghz,6Mram,24x2TB Disks, Software: WHS 2011 64 bit OS, SageTV 7.19, Digiguide,XML Importer, DVBLogic, Oscam,mymovies 4.02
Old 01-28-2011, 12:07 PM
ruwackd ruwackd is offline
babgvant posted a guide for installing sagetv 7 and in it shows the steps to install ffdshow to enable bitstreaming of the hd audio formats in the sage player. Hope this helps
http://www.missingremote.com/guide/i...ng-sagetv-v7-0
Old 01-28-2011, 02:16 PM
Thanks for the pointer, I'm wondering how specific that is to the native support the HD5450 offers in H/W?
Old 02-10-2011, 05:40 PM
GollyJer's Avatar
GollyJer GollyJer is offline
This works great burtonpark.
Quick Guide: How to Bitstream Audio in Windows 7 Warning... Shark007 installs Bing Bar without warning. You'll need to remove it via add/remove programs. I'm currently looking into another codec pack that provides the same functionality but doesn't install Bing.
Currently using SageTV Media Center Server on Windows 7, SageTV Client as an HTPC on Windows 7, and an HD Theater HD200. The server controls 3 Motorola DCH-3200 cable boxes and 3 Hauppauge HD-PVRs (all Rev F1) with HD audio and changes channels via firewire WITH NO LOCKUPS. It's awesome.
4 Steps to Perfect Stutter Free Playback for SageTV
Old 02-10-2011, 05:50 PM
Spectrum Spectrum is offline
Apparantly enough people gave shark hell about it so he posted 2 reg files that make Bing think it's installed so it won't install. I tested on Win7 x64 in a VM and they worked; no trace of the bing bar.
@GollyJer I'll try to run through the shark pack again this weekend and I'll post my results on your blag. I haven't forgotten, just haven't had time when I could work on the box that it wouldn't conflict with it's duties Although, I would rather just use an SVN build of ffdshow and install the PowerDVD codecs manually. I haven't been able to figure out the PowerDVD part yet though.
Old 02-11-2011, 12:03 PM
GollyJer's Avatar
Which is why Shark007 is so nice. :-) That, and the simplicity with which you can disable Media Foundation (the settings on the SWAP tab), make it well worth the install. Hope to hear from you on the blog.
Old 02-13-2011, 12:52 PM
Thanks guys I'll give it a whirl
HD 300--Audio Question (Bitstream and Analog Out at Same Time?) civerson4 SageTV Media Extender 3 12-28-2010 06:24 PM
Any used an ATI 5450 and 5570 yet? RyanW Hardware Support 6 03-11-2010 06:56 PM
Audio Setup nycjoe Hardware Support 1 01-31-2010 02:10 PM
HD100 and digital bitstream for audio frontlinegeek SageTV Media Extender 4 11-25-2008 08:01 PM
MKV/H.264 Bitstream Aspect Ratio Utility Taddeusz General Discussion 0 01-18-2008 02:48 PM
