Old 05-25-2011, 11:37 AM
dead_ferrets dead_ferrets is offline
HD-PVR replacement power supply
Hi folks,
After literally months of flawless performance my HD-PVR is suddenly cutting in and out on recordings and live tv. After about 30 minutes of operation is it seems to be losing and reacquiring the signal, at increasing intervals. Nothing at all has changed on the system or cable box.
I am suspecting a faulty power supply. Can someone with some power supply savvy give me a link or advice on a replacement? I'v spent an hour or scouring various sites but can't seem to find anything suitable.
Thanks.
Old 05-25-2011, 11:51 AM
DMT DMT is offline
I had one of my power adapters go bad. It tested ok for voltage but didn't power up sequence the HD PVR like it should. I emailed Hauppauge support and they sent me a free replacement within a week!
SageTV 7.1.9 on Win 7 Ultimate x86; Intel DH67CF, i3-2100T, 4GB DDR3, 60GB SSD, 8TB Drive Bender storage pool, blu-ray. 2x HD PVR (SA 4250HD firewire channel change), 2x HD200 extenders (external IR receiver mod, HD300 remotes).
Plugins: Custom Main Menu, Enable/Disable Favorites, Stock Manager, Web Interface, Mobile Web Interface, PlayOn
Old 05-25-2011, 11:56 AM
Thanks DMT. I will email Hauppauge support. Now to cross my fingers and hope it solves the problem!
Old 05-25-2011, 12:05 PM
monetteboy monetteboy is offline
I had two of mine go bad here recently. I found these on Amazon and they worked fine (in case you can't wait on support).
http://www.amazon.com/gp/product/B0044QMAFY
Old 05-25-2011, 06:04 PM
stevech stevech is offline
My Rev. F unit has a 5VDC, 2Amp power transformer. Pretty common. If you're not a EE-type, the voltage must be 5.0VDC but the current rating can be 2Amps or more.
Just get a connector that's the correct diameter and pin size- there are about 3 variations. Or cut and splice!
I think mine's a bit undersized for a 2Amp unit.
It's brand-marked Hauppauge though, which is unusual.
Old 05-26-2011, 07:59 AM
Thanks for the help folks. Much appreciated.
HD PVR power supply tvmaster2 Hardware Support 13 01-12-2012 03:13 PM
HD Theater 300 Power Supply Oddity SageTV Media Extender 3 12-06-2010 01:13 PM
Replacement power supply/adapter for SageTV Media Extender moakes Hardware Support 2 06-14-2009 09:11 PM
HD PVR power supply Fingergottes Hardware Support 1 09-22-2008 01:13 PM
power supply opinions, please hemicuda The SageTV Community 6 06-12-2008 08:29 AM
