Old 12-01-2012, 10:57 PM
mike015pgh mike015pgh is offline
Weather doesn't update.
i have sage 7.0.23.246 and my weather hasnt updated since 7-2-12, 5 months ago. i have tried adding the google weather plugin. uninstalling rebooting reinstalling. still shows the weather channel info. any ideas on what i can do to get a working weather in the default STV. i have phoenix installed and if i use that i do get weather updates. but i dont care for the look.
Mike
Old 12-04-2012, 05:01 PM
Upgrade to SageTV 7.1.9. Using that and only that I have current weather. With latest STV updates of course.
Old 12-06-2012, 12:30 AM
rantonow rantonow is offline
Weather Channel
I believe I read that the issue is directly with the Weather Channel where the data comes from and not Sage itself. Something about WC no longer providing a free feed so downloads stop. Sux for me here in Denver as mine stopped updating on one of the hotest days of the Summer so every time I go to the main menu, I see it is 100 degrees outside (OK actually it is pretty cool when it is really 10 outside). I would like to know if there is some way to then just turn off the weather display in the title bar so that I dont have to see that anymore. The better fix would be to make the Weather update start working again...
Sage advocate since V2.2; Ahanix MCE701 MCE Multimedia case; Gigabyte MB, e6600 Core2Duo 3.0Ghz; GeForce 8600 PCIe; 4 GB DDR-1033; Dual Hauppauge 1600 HD OTA tuners; HD-PVR connected to Dish Network 211 receiver. RAID 1 500GB Sata2 + 1.5TB CAVIER recordings drive; Windows Server 2003; Sage TV 7; 2 STX-HD200 Media Extenders
Old 12-06-2012, 06:53 AM
It works fine in 7.1.9. That is the only update that will happen.
SageMC weather update? BigSwifty SageMC Custom Interface 14 04-03-2013 10:19 AM
Features of the weather system update Opus4 SageTV Software 5 10-16-2012 12:29 PM
Downloaded Google Weather Update, No weather? symgryph SageTV v7 Customizations 3 11-18-2011 08:55 AM
Weather wont update anymore dc9mm SageTV Software 1 11-09-2011 10:19 PM
24-Hour Weather Update Only Beaker SageTV Software 6 06-16-2008 04:23 PM
