Old 12-20-2014, 01:09 PM
graywolf's Avatar
graywolf graywolf is offline
Switching Service Provider - What to consider?
Currently with DirecTV (non-HD). Might be considering switching to DISH or TWC Cable (cost considerations).
Just trying to think what all would be involved with SageTV setup.
DISH I think would be simply changing video source/lineup, reconfigure usb-uirt
for non-HD channels, would need to get HD-PVR or Collosous for HD.
TWC - If have box, change source/lineup, reconfigure usb-uirt
If no box - ????
Also - if I recall, cable has copy flags...how could I determine what TWC copy flags are prior to getting them?
Anything else I might not even be considering?
Of course, once I'm fully aware what would be involved to reconfigure SageTV and decide which way to go, I'll give DirecTV customer retention department a chance to keep me as a long time customer. Don't want to go there though until I'm ready to move/switch if needed.
Old 12-20-2014, 01:38 PM
KryptoNyte's Avatar
KryptoNyte KryptoNyte is online now
I believe that for all regions, the only Time Warner channels that are "copy-freely" are your local affiliate channels. You could use a HDHRPrime with cablecard for the local channels, or possibly a QAM tuner if Time Warner is still broadcasting all their local affiliates in the clear (I prefer the cablecard regardless, it's worth $2.50 a month to not have to worry about channel mapping, and remapping when Time Warner screws with it).
You would then need one set-top-box and an HDPVR (or colossus) to record all non-local channels, with the USBUIRT channel changes.
Old 12-21-2014, 01:53 PM
As long as you are using a HD-PVR or Collosus then you don't need to worry about the copy flags as they don't apply to analog outputs. They are only an issue if you use a CableCARD tuner.
Problem Switching to Service Mode jimbo67 SageTV Software 5 02-11-2011 03:29 PM
Switching to service mode question Beefcake550 SageTV Software 1 11-24-2008 11:01 PM
Service Provider Not Listed CarolinaGuy SageTV EPG Service 2 11-15-2006 09:05 PM
Switching from Regular to Service: Propreties File Help Berg SageTV Software 5 10-11-2006 06:22 PM
Switching to service mode? AngelofDeth SageTV Media Extender 8 08-04-2006 04:11 PM
