Old 11-05-2017, 02:20 PM
bachurch bachurch is offline
Schedules Direct EPG Issue
I have the latest Sage Ver 9.1.7.757 and an account at Schedules Direct. The issue I'm having is with any Station ID's that are only a 3 digit number the guide won't update any programing. The ones that have a 5 digit Station ID work fine. In looking at the log file for json scheduler I only see 5 digit Station ID for the following stations.
ttps://json.schedulesdirect.org/20141201/lineups/USA-IL12468-DEFAULT (received):
{"map":[{"stationID":"14948","channel":"002"},{"stationID":"53049","channel":"003"},{"stationID":"11498","channel":"004"},
{"stationID":"11069","channel":"005"},{"stationID":"10823","channel":"006"},{"stationID":"10543","channel":"007"},
{"stationID":"11798","channel":"008"},{"stationID":"23885","channel":"009"},{"stationID":"11805","channel":"010"},
If I map the old channel to channel that has the 5 station ID over to the channel that only has a 3 station ID that I'm not receiving programing data on that channels starts to work. I have about a 1/3 of my channels that aren't receiving data.
Is there a setting in Sage that can change the channel ID to match what is being downloaded from json schedulesdirect?
The following is the channel guide that I'm using.
https://mediacomtoday-lineup.com/lin...rt_durant.aspx
I've been thru the forums and haven't found a solution to this.
I've put in a ticket in to Robert Kulagowski via RT at schedules direct and he doesn't see a problem on his end.
Thanks for your time.
Bob
Old 11-05-2017, 07:43 PM
JustFred JustFred is offline
In all probability, Schedules Direct is working the way it should. 5-digit channel ID are the norm. Have a look in the Sage TV Users Guide pdf, under "Remapping Stations for EPG data using ATSC or QAM Digital Tuners". Wherever the manual says Zap2it, think Schedules Direct.
Old 11-06-2017, 05:45 AM
EnterNoEscape's Avatar
I'm not sure I have ever come across a 3 digit station ID. Are those something you entered manually?
Old 11-06-2017, 06:51 PM
Denali Denali is offline
I would get 3 digit station IDs when I manually entered an OTA subchannel not in provided Guide Data.
HTPC: Gigabyte GA-Z170XP-SLI, I7-6700, 16GB, Windows 10 Pro x64, Hauppauge HVR-1600, WinTV-dualHD, Colossus 2, Samsung 850 EVO 120GB, Seagate 3TB, WD 3TB, 3TB, 5TB, Java v1.8.0_201, SageTVx64 v9.2.1.826, Samsung UN60EH6003F, Dish ViP222K, ViewHD 1x2 HDMI Splitter.
Old 11-07-2017, 07:02 AM
Tiki's Avatar
Tiki Tiki is offline
If it's not part of the guide data, how are you getting a station ID at all? Normally the station ID comes from the EPG provider. Does Sage create one for custom channels?
,USBUIRT (multi-zone)
Source:
Comcast Cable
HDHR, HVR-2250
Old 11-07-2017, 06:14 PM
It appears so.
Schedules Direct "No Data" issue crarbo1 SageTV EPG Service 10 06-18-2017 06:07 PM
2017-06-07: Schedules Direct service issue rkulagow SageTV EPG Service 1 06-10-2017 12:35 PM
Schedules Direct "No Data" issue SDeGonge SageTV EPG Service 15 04-16-2017 07:12 PM
Using Schedules Direct in UK jamesdisco SageTV United Kingdom 28 02-06-2017 11:54 AM
Schedules Direct Plugin Issue rickgillyon SageTV v9 Customizations 20 09-25-2016 12:03 PM
