Old 01-13-2019, 03:10 PM
jpwegas jpwegas is offline
Extra "TV Tuner" channels
Recently when I've added a new network encoder Video Source, it adds a bunch of useless "TV Tuner" channels numbered 1-158 to the lineup. These seem to correspond to the old broadcast number range but strangely they do NOT exist in the "base" SD lineup that I copied from.
Does anyone know how to prevent these from being created? My older (created pre-v9) network encoders don't have these channels but recently created network encoders do.
Or does anyone know a safe way to remove them permanently from the lineup? I know I can just disable them but I'd like to clean up the extra channels possible.
--John
Old 01-13-2019, 04:06 PM
--John
Have you tried to "Remove all remapped channels" when installing a tuner from the network encoder? Not sure that will help but I found it got rid of some weird channels for me.
Old 01-13-2019, 05:49 PM
Ooops! I tried removing the remapped channels but it removed all the channels from the BASE lineup and left the bogus "TV Tuner" channels!!!
"The lineup had 902 channels"
"After clearing remappings on 744 channels, 744 channels were removed."
"The lineup now has 158 channels."
Is this really the intended behavior when you are working with a copied channel lineup? Doesn't seem useful...
--John
"Backdrops" "SageTV" "Covers" folders - what's creating them mp328 Sage My Movies 4 09-20-2010 05:31 PM
"Not Manual Recording" filtering doesn't work in SageTV's "Upcoming Movies" menu vince100 SageTV Customizations 3 11-23-2009 03:56 PM
"Set defaults" for Series forgets "Keep"/"Auto-delete" setting maxpower SageMC Custom Interface 9 05-14-2008 09:44 PM
extra "Archive" folder please!? bigbbri SageTV Customizations 0 01-08-2006 11:56 PM
"Dual Tuner" card vs dual "Tuner Cards"? kelemvor Hardware Support 8 10-17-2005 10:01 AM
