Old 11-28-2007, 02:26 PM
neilbradley neilbradley is offline
Send a message via MSN to neilbradley
Component or HDMI capture?
I've gone over the threads on the hardware list looking for HD capture devices, either by way of HDMI or by component, and I saw reference to the Blackmagic devices, but nothing conclusive as to what would and wouldn't work with SageTV.
So what is the current recommended hardware that will capture HD, either via component or HDMI, and works with SageTV? Thanks!
Old 11-28-2007, 02:53 PM
GKusnick's Avatar
GKusnick GKusnick is offline
The conclusion of all those threads is that there aren't any such devices suitable for use with Sage. The Blackmagic devices are meant for professional DVD authoring. They don't do HD, and their SD bit rates and file sizes are way too high for DVR use.
-- Greg
Old 11-28-2007, 03:12 PM
NEOSG NEOSG is offline
depending on your provider, an R5000 modded STB may be an option for you. google r5000
Old 11-28-2007, 03:35 PM
lobosrul's Avatar
lobosrul lobosrul is offline
Actually, they do, do HD. Impractical to use as a DVR though, thats been discussed ad nauseum.
Old 11-28-2007, 04:45 PM
Fluffdaddy Fluffdaddy is offline
Your only real option is the R5000-HD mod
http://www.nextcomwireless.com/r5000/products.htm
Old 03-21-2011, 12:28 AM
STEVON STEVON is offline
HDMI in is possible
If you are worried about HDCP encryption, don't. Buy a Hauppauge Colossus card and a MUX-HD. Works for HDMI STB, Blu-Ray or PS3.
Old 03-21-2011, 09:55 AM
A MUX-HD only provides DVI output. How does that work with a Colossus card? And don't you need also need a TOSLink input to get your audio? And according to your other posts you don't have it working with the Colossus card.
Old 03-24-2011, 11:12 AM
Savage1701 Savage1701 is offline
You could also look at the HD-Fury 3. It claims (I can't validate this personally) to use a higher-quality HDMI (that WILL accept HDCP signals) and down-convert it with much higher quality to Component Video (better gamma, contrast, etc.) at your choice of 1080i or 1080p. It will also go as low as 480i if you needed it to. It's about $250. Pricey, but about the only legal HDCP-stripper out there if you are willing to accept a slight loss of quality of Component, most of which they claim they have made up for.
I know the Hauppauge devices only handle 1080i or less, but nice to know 1080p is there if your TV will take it. Version 3 also handles 2 HDMI inputs. I don't know about audio.
Also, there are threads in here where you can jack the encode rate of the HD-PVR up higher. I've done it - it gets it up to about 16Mb/s, or 7.9GB per hour. It is noticeably better than the default maximum 13.5 Mb/s rate, and easy to add to the properties file.
Asus P5Q Premium MB, E6750, 4GB RAM, 32-bit XP Pro SP3, 3Ware 9590SE controller, 80GB 7.2K Laptop boot drive w/SuperSpeed Cache Utility & eBoostr, (1) KWorld ATSC-110, (1) 950Q USB, (1) 2250 tuner, (1) HD-PVR using USB-UIRT, (1) 1600 Dual card, (1) DVICO Fusion 5 Gold, (1) Hauppauge 1250, (1) Hauppauge 2250, 8 various storage HD's, NEC-based x1 USB add-on card, 2 outdoor antennas capturing 2 different OTA markets, Dish Network w/HD Receiver for HD-PVR.
New tools for Studio users GKusnick SageTV Studio 206 11-29-2009 10:08 PM
Puzzled: Sage not using 3rd tuner wvpolekat SageTV Software 2 11-15-2007 01:36 PM
HDMI or Component ??? Ken C Hardware Support 1 10-01-2007 08:47 AM
AUUUGH I Give UP!!! TripleTapper SageTV Media Extender 46 01-03-2006 02:35 PM
