Old 04-30-2008, 07:55 PM
yacht_boy yacht_boy is offline
Hauppauge Remote Issue
Hi all-
I tried installing Sage about a year ago and could never get it to change channels correctly with the Hauppauge remote and IR blaster. Eventually I got TiVo and was using that for a while, but I wanted something more configurable and decided to give my home-made solution another whirl. Having determined that the problem was with the Hauppauge IR blaster, I bought a USB-UIRT and started over.
I did a fresh install of Windows MCE on my machine (1.5 gb ram, 460 total gb HD space, Hauppauge PVR-150 with 45-button remote), reloaded all the necessary drivers and fired it up.
I could get windows MCE working fine with the remote but ran into other issues configuring the card, so I quickly decided to move on to Sage.
I got Sage's latest version as of today, 6.3.whatever and ran it on this clean new install with all Hauppauge IR drivers already installed.
Everything is working now EXCEPT the remote. I checked the appropriate buttons during install, even uninstalled and reinstalled Sage to make sure I'd done it right, and....nothing.
I know the remote is working because A) it would control MCE and B) I can see the red light from the USB-UIRT respond when I push buttons on the remote. So why can't I get the remote to control Sage?
Some sort of quick resolution would help, because the girlfriend will quickly rebel and force me back to the TiVo if I don't get this fixed
Any and all help greatly appreciated.
Jason
Old 04-30-2008, 08:55 PM
If you really have a Hauppauge remote & not an MCE remote from a Hauppauge MCE kit version of the tuner, then try this FAQ:
How do I use the Hauppauge remote to control SageTV? When I press a button, nothing happens..
Old 05-01-2008, 07:34 PM
Thanks--there are a lot of threads floating around here about remotes, I couldn't find that one when I was searching last night!
It seems to be working fine for now as long as Sage is in focus, except for the volume. I am running a Diamond Extreme 7.1 Surround Sound card with optical out to my 5.1 home theater optical plug. The remote volume will lower the side channels but not the center channel. Mute works, though. Any suggestions?
Thanks again--
Jason
Old 05-01-2008, 09:09 PM
I don't know about the volume issue, but for this:
Chek that same FAQ, towards the end, or see post 15 of Hauppauge link 3 in my sig lines.
Old 05-01-2008, 09:25 PM
thanks--once I get this set up properly, this machine will be dedicated to Sage, so I figured I wouldn't mess around with the focus thing. I'll keep poking around for a volume solution.
Jason
New MCE Remote Software StephaneM Hardware Support 298 11-23-2009 06:13 PM
Information Resources for Remotes, Receivers, and IR Blasters Opus4 Hardware Support 4 09-17-2009 01:37 PM
Silver Hauppauge Remote acemarvel SageTV Linux 3 09-13-2007 09:58 PM
Hauppauge Remote Control problem - Sage v2.1 Boxpin Hardware Support 2 05-19-2006 05:34 PM
hauppauge remote not working with MVP when using SAGE vsieferm SageTV Media Extender 5 02-15-2006 01:03 AM
