Controlling Multiple STBs
I have spent a good deal of time trying to sort this out and searching through the forums. I am certain this has been asked hundreds of times already, but I must be searching the wrong thing in the forum.
What are most of you using to control multiple STBs? Since I last connected my Sage box over a year ago, I was living in an area with Charter. I now live in an area with Comcast, and it appears they have disabled the serial port on their Motorla STBs. Which is a shame, because serial port control worked SO WELL! By comparison, I dusted off my USB-UIRT and while it works, channel changing seems "Slow and clunky" in comparison. Also, while I can easily find how to purchase the USB-UIRT - finding the IR Blaster to use with it is not possible. If I am going to use the USB-UIRT, how do I use it to control multiple STBs? Also, one of the problems I have with the USB-UIRT is that it must face the STB. If I wanted to get rid of my streamzap IR receiver and use the IR receiver in the USB-UIRT, I would have to face the UIRT forward and the IR Transmitter inside the UIRT would not be able to control the STB. I am really having a hard time picturing how those of you with the UIRT have it setup to allow both receive and transmit functions. I read elsewhere in the forum about using the UIRT with zones. Will the double-headed IR Blaster from this site work with the UIRT? For that matter, could I use the RS232 IR Blaster featured on the same page? To me, that seems like a much more elegant setup than using the UIRT. |
When you use zones for the USB-UIRT, the 1/8" jack provides for zones 1 and 2 and the USB-UIRT itself would provide zone 3 (and thus the USB-UIRT would need to face the third STB. EDIT: I used a 1/8" stereo plug to 1/8" Mono jack (Left) and 1/8" Mono jack (Right) adapter that I got at Radio Shack and my two emitters from an old MS eHome IR setup. The USB-UIRT works very well.
Server: SageTV 9, Win10/32, Intel DP55KG Mb, Intel QC i5 2.66GHz , 4GB 1333MHz DDR3 SDRAM, 2 Hauppauge 2255s for 4 OTA ATSC tuners, HDHRPrime w Comcast, 3 STP-HD300s 20101007-0 firmware, nVidia Shield. Java v7u55. Plugins:SD EPG, OpenDCT Last edited by HelenWeathers; 07-26-2009 at 01:42 PM. |
The only IR blaster I have currently is the one that came with another hauppauge card. It has a combo receiver/transmitter on one cable with a micro connector (I forget the technical term for these connectors, but we'll call the really small one the one that you find on most cell phones).
I don't understand why the UIRT has support for additional blasters but doesn't provide any information one what to use or where to get them. |
What Direct TV STBs work well with HD-PVR and how are you controlling them? | sagestuff | Hardware Support | 5 | 02-25-2009 09:30 PM |
Multiple STBs, Same Provider, Different Lineups? | bretm | SageTV EPG Service | 3 | 01-31-2008 02:47 PM |
Multiple Tuners and Satellite STBs | kamikaze2112 | Hardware Support | 8 | 07-01-2007 10:08 PM |
Controlling recievers/STBs | GlobalFear | Hardware Support | 2 | 04-03-2006 02:03 PM |
using multiple pvr150s to tune multiple external stbs | nick_l | Hardware Support | 3 | 03-13-2006 01:05 PM |
