The setup I have now has reached it's limit. I'm going to be buying a new Motherboard, few more Seagate 1.5TB drives, and soon a 5th SageTV HD Theater for my wifes room.
I'll be setting up multipul networks, one for internet / ReadyNAS, 2 for my 4x HDHomeRuns, and one for the 5x SageTV HD Theaters. As it stands now I have a system drive, a 500 gig drive for sage, and a 1.5TB drive for the recordings. I want to add a few 1.5TB drives, but I am trying to figure out if I want to raid the drives or if I want to keep them separate and just let Sage figure out what drive to use. Recording a few things and playing back on two front ends seems to be pretty taxing on one drive. Here is my question. If the schedule is set up to record 6-8 things at once, and there are 4 drives with plenty of space left, will Sage use all 4 drives or will it just use one? Maybe I could set it up so that these two tuners use drive A, these two use drive B and so on... |
Side note, if I decided to use a raid, I would be using a real raid controller not on board. Proly:
http://www.adaptec.com/en-US/product...lue/SAS-31205/ Anyway what are your thoughts on optimal storage in a pretty tech heavy home with 3 kids? |
Tags |
hdd, multi hdd, sagetv hd theater |
Would Sage benefit from multi-core, multi cpu configurations? | kamikaze2112 | Hardware Support | 10 | 09-26-2008 09:13 AM |
Multi-Tuner Setup | Alwayslearnin | Hardware Support | 1 | 06-26-2005 09:48 PM |
Help with multi tuner | Aganerral | SageTV Software | 2 | 11-09-2004 10:50 AM |
Multi-Tuner Multi- User System Question | mightyt | SageTV Software | 2 | 09-11-2004 05:49 PM |
Going to add USB2 tuner to multi tuner setup. | ToxMox | Hardware Support | 9 | 03-05-2004 10:41 PM |
