Old 09-03-2010, 08:09 AM
dinki's Avatar
dinki dinki is offline
HD300 wake on lan
Any chance of getting WOL for the HD200 or does it require hardware than only the HD300 has? If it's just code, can it be ported to the HD200 firmware?
Old 09-03-2010, 03:29 PM
RocKKer RocKKer is offline
Would this work?
Run from the server or somewhere else on your network.
SageTV Server v9.2.2, Ubuntu Server 18.04.4 x64, Java 1.8.0_252, Xeon E5-2690, 32GB, 6X6TB WD Red - Software Raid 6, 2X HDHR3 (OTA), 3X HD-200
Old 09-03-2010, 03:50 PM
dinki's Avatar
Originally Posted by RocKKer View Post
Would this work?
Hmm. Thanks for the reply, but that's not really what I'm trying to do. I guess I could have been a bit more descriptive.
What I'd like to do is be able to have my sage server put itself to sleep when it's not doing anything but have the ability to have the hd200 wake it up when I power on the hd200. I think the hd300 can do this and am wondering if they can port that code to the hd200.
I've also seen the program/service that looks for the extenders to power on and send the WOL to the sage server. The problem with that method is that it needs an always-on pc and I'm trying to get away from that.
Old 09-04-2010, 05:23 PM
Gotcha, I understand now.
Old 09-06-2010, 01:54 PM
valnar valnar is offline
The GNU wol command is very small and should be easy to implement. I'd like to understand why they can't.
Old 09-06-2010, 03:41 PM
dinki's Avatar
I've sent an email to support and hope to get an official answer soon.
Old 09-10-2010, 01:35 AM
starfire starfire is offline
Did you hear anything back?
Old 09-10-2010, 08:05 AM
dinki's Avatar
I've been out for a bit and hadn't gotten a chance to post. Here's the reply:
Unfortunately that is not currently supported on the HD200. I don't know
if/when it will have that support. I will pass this along as a suggestion to
the developers.
George Oms
SageTV, LLC
Old 09-11-2010, 05:00 AM
OK thanks, hopefully they can add this to HD100 & HD200
Old 11-02-2013, 10:50 PM
tvmaster2's Avatar
did you ever find a way to make the HD200's send a wake up command, or did Sage get sold before this ever got done....
Old 11-02-2013, 11:16 PM
KryptoNyte's Avatar
I never found a solution to this, but when I was using the HD200's, I found a WOL app for my Android phone and was able to wake the server. It wasn't what I'd call elegant, but it worked. It was also fairly handy in testing the WOL capability of the server.
Old 11-02-2013, 11:32 PM
tvmaster2's Avatar
cool...I use android phone. better than nothing...do you have the app name handy?
Old 11-03-2013, 04:20 AM
routerunner's Avatar
If you're currently using the Logitech Squeezebox way to listen to music, you might like to know that I've implemented WOL magic packets support to all extenders (MediaMVP inclusive) as part of the Squeezeslave project.
Cheers
Eddy
Old 11-03-2013, 06:35 AM
KryptoNyte's Avatar
There are quite a few available. I think it was the first hit in the Google Play search for Wake on Lan:
https://play.google.com/store/apps/d...roid.wakeonlan
Old 11-03-2013, 06:36 AM
KryptoNyte's Avatar
Cheers
Eddy
Thanks, Eddy. That's a slick feature.
HD300? jpaddock3000 General Discussion 64 07-04-2010 06:16 PM
Wake on LAN / EPG updates? Dingdul SageTV Beta Test Software 1 05-31-2010 08:12 PM
HD-200: Wake On Lan or similar? Moskus SageTV Media Extender 4 05-03-2009 07:55 AM
STX-HD100 wake on lan? Skybolt SageTV Media Extender 10 01-30-2009 02:04 PM
Client issues. shuttering frames on wireless lan not wierd lan IKK SageTV Software 8 01-17-2004 10:35 AM
