Old 11-19-2012, 01:55 PM
sacrament055 sacrament055 is offline
Phoenix Core Services problem
I'm not sure if this is the place to post it but I'm noticing that my phoneix core services on my client PC dies after the first reboot.
When I initially install it it's working find but when I exit and restart sage it shows failed.
If I uninstall then exit and restart sage it will work again until the following restart.
As a result of this I can't run Gemstone on my client and it appears phoenix core corrupts, or is doing something to my googleweather api as it stops working after phoenixcore services is installed. Once I remove phoenix core and remove re-install googlewether-api my weather comes back and works fine even after a reboot.
Old 11-19-2012, 02:04 PM
jusjoken jusjoken is offline
Look in the sage logs and see what the error for the failed plugin is saying.
Old 11-19-2012, 05:21 PM
I'm including the Sage Client log.. Not sure if that's all you need.
Old 11-19-2012, 05:43 PM
Perhaps Stuckless can comment on what this error is but I think it's related to a phoenix dependency not found...
ERROR loading plugin class sagex.phoenix.plugin.PhoenixPlugin of:java.lang.NoClassDefFoundError: sagex/plugin/AbstractPlugin
Loading of plugin phoenix-core failed!
Besides this, the log file is full of exceptions... so much so it looks like some jar files must be missing or corrupt.
WIcons is failing... if you are using the latest SageTV and the new google weather then you should disable or uninstall WIcons as they are not compatible.
There are also many errors similar to...
java.lang.NoClassDefFoundError: Could not initialize class tmiranda.rpad.Log
Again... not sure what plugin this is from but it is certainly failing.
Not sure this helped but perhaps someone else can jump in and assist in suggesting something to clean this up.
k
Old 11-19-2012, 07:04 PM
I went through and removed all plugins via the ui when gemstone wouldn't work then installed phoenix core and noticed that failed after a reboot. I guess i could just clean install sage again since its a client not my server.
Thanks for your help
Old 11-20-2012, 06:08 AM
Because of this error...
It seem as if the sagex-api didn't get extracted correctly. This is a very base and core library that is used but many plugins... so if it doesn't extract correctly then I can see you having issues with several plugins, including Phoenix core.
Old 11-20-2012, 08:09 AM
panteragstk's Avatar
Same issue with new client. Kinda odd.
Old 11-20-2012, 11:27 AM
Ok so at least its not just me working fine on my server though
Old 11-20-2012, 02:44 PM
You're response gave me the clue of how to fix it for me. I took the known good jars from my server and copied them to my client and now all is fine.
Old 11-20-2012, 09:59 PM
This is still happening just did a clean Install and it fails on extracting will not update property files so cannot just copy from a working client.
Old 11-21-2012, 05:05 AM
Does it give an error during the extracting? ie, permissions, etc. Sometimes SageTV will track when files are not full extracted and it will attempt to do it again during the next restart. So I would restart the client and see if fixes it.
Old 11-21-2012, 07:50 AM
All other plugins extract and install except for the Phoenix Core part. I tried restarting rebooting same error.
Screen attached.
Old 11-21-2012, 08:49 AM
Screen attached.
can you send your sagetv_0.txt debug log as well... If sage failed to extract this, then the error should exist in the sagetv log file.
Old 11-21-2012, 09:55 AM
Stuckless,
I started from scratch ... Installed phoenix core and sagex api and it installed fine.
log attached.
Old 11-21-2012, 10:15 AM
Stuckless,
log attached.
So it's now working? Again, I've seen this from time to time where Sage will not extract a plugin correctly (permissions, or some other random error), and when that happens, you can't actually force a plugin to reload/reextract, you have to unload it, and all the dependent plugin, and start over. There needs to be a way in sage to just "refresh" a single plugin
Old 11-21-2012, 10:37 AM
Guess what it failed on my 2nd client. It must be a permission issue on my 2nd client. It does not create the C:\Program Files (x86)\SageTV\SageTV\STVs\Phoenix folder
log attached.
Eureka... I found the problem.
In the one I had a problem installing with I had it load at startup fullscreen In windows 8... Windows 8 security is a lot tighter so I had to run as administrator. Even though my logon has administrator privileges. In the one that it was working on is because I start sagetv manually once I am logged on.
Utility: Phoenix Tools - Phoenix Renamer stuckless SageTV v7 Customizations 116 04-27-2017 10:42 AM
Problem Installing Latest Phoenix joejoeyjojo Phoenix 1 01-31-2012 07:33 AM
Phoenix Source (and how to rebuild Phoenix from sources) stuckless Phoenix 2 09-22-2011 10:26 PM
Problem with Phoenix landing page / Status sflamm Phoenix 3 08-24-2011 10:12 AM
Latest Phoenix Fanart 1.0.4 problem or feature? sacrament055 SageTV v7 Customizations 2 07-31-2011 10:09 PM
