A new Hauppauge PCIe coming soon.
Just found there a new Colossus 2 with HDMI in and out with 1902x1080p60 support and SPDIF which will be available mid-summer sorry no photo
I would expect it not to work with Sage unless you can come up with some tweaks. Would be nice if it would work reliably unlike the other one (for many of us)
I found that my original colossus either was a defective card or was in too cramped and hot a case. Because now that I've switched to a new card in a larger and cooler case I'm not having nearly the problems I use to. It is allot more reliable now. Instead of at least one to two bad recordings a week (sometimes was one or two a day) I now get one to three a month maybe less. My HDPVRs (1212s) are one or two bad/failed recordings every quarter or less - I can go 9 months without a problem then get a bunch then none for a long time again on my 1212s.
"Keep your goals away from the trolls" |
Just found out Basically, it same as HD PVR 2 model 1512 just on a PCIe board so you know what that means there a very good possible that it will with SageTV
If someone could convince Hauppauge to include basic command line tools that can be used to capture from these cards then Sage support is a snap via the network encoder protocol. The same thing could be done otherwise, but would require DirectShow development of some kind, which is way more effort -- not worth the effort to me nor to anybody else, apparently.
Give me a command line tool that I can trigger capturing to a file as needed then writing the network encoder to support it in Sage is relatively quick and easy.
Twitter: @ddb_db Server: Intel i5-4570 Quad Core, 16GB RAM, 1 x 128GB OS SSD (Win7 Pro x64 SP1), 1 x 2TB media drive Capture: 2 x Colossus STB Controller: 1 x USB-UIRT Software:Java 1.7.0_71; SageTV 7.1.9 Clients: 1 x HD300, 2 x HD200, 1 x SageClient, 1 x PlaceShifter Plugins: Too many to list now... |
Martin |
Not sure, don't have one, but I thought there was some registry hack to make it appear like an original HDPVR to Sage? If so, then no, it's using Sage's core to control it.
Part of that was about make HDMI Audio and SPDIF Audio work as first HD-PVR 2 didn't came with it SPDIF just like first HD-PVR didn't come with HDMI so I wouldn't go as far as calling it a hack but it is registry add on which SageTV has always had and there are two way to do it in order for SageTV to see the Unknown Device and if I'm right with Colossus 2 that should work out of the box as HDMI Audio and SPDIF Audio are all ready in place with the Colossus so it just a matter of add in the registry for sage to see the device so we can hope that it just work.
Hope we make it work with SageTV and it doesn't have the same memory leak problem as the first gen Colossus requiring nightly reboots. I being to notice that one of my Colossus is showing sign of device not detected one a while requiring a reboot to make it detectable again by SageTV so it probably on it last leg and the Colossus 2 would be a nice replacement for it if someone write a SageTV driver for it. Bill
HTPC System GIGABYTE GA-MA69GM-S2H AM2 AMD 690G HDMI // AMD Athlon 64 X2 6000+ Windsor 3.0GHz // G.SKILL 6GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR // Hauppauge Colossus HD-PVR // Hauppauge Colossus HD-PVR // Seagate ST3750640AS 750GB SATA-300 16MB // DVD R/W - SAMSUNG Black Media Extenders HD300 HTPC Software Windows 7 Professional 64bits // SageTV 7.1.x // Java 1.7.x |
So ... is the HD-PVR2 capable of recording 5.1 channel audio via ... any method?
Thanks, SHS. I was thinking the HD-PVR2 hardware never got past stereo audio.
Any update on this?
Bill
Nothing as of right now Bill last I heard they working on new Rev Board, It use lee take a bit of time iron out any bug in the board layout, But I check with them to see what up.
Won't this still have the same sound issues as the HDPVR 2?
What I'm ref to is having all the input show up with out having to modding the Hardware INF. |
Yes, the sound issues on extenders. Though I believe some others had similar "no sound" issues with the client software, depending on which codecs they were using.
I wasn't aware of that on the client but I don't remember seeing any.
Ceton PCIe or USB? | DaveS | Hardware Support | 11 | 01-05-2012 11:27 AM |
Hauppauge Collosus PCIe passthrough under ESXi? | patja | Hardware Support | 2 | 07-06-2011 03:11 PM |
TV Wonder HD 650 PCIe or WinTV HVR-1800 PCIe? | phenixdragon | Hardware Support | 0 | 12-10-2007 06:42 PM |
vBox dual tuner HDTV PCIe (Cat's Eye e154) coming first quarter | ToxMox | Hardware Support | 3 | 01-26-2006 10:58 AM |
Hmm, new Hauppauge HD card coming? | LYU370 | Hardware Support | 8 | 01-07-2005 02:21 PM |
