One Other Colossus v1 Question
Also was curious, am I better off staying with USB-UIRT or has Hauppauge gotten the IR blaster to work with Dish? If memory serves, there was also a conflict that if I had more than one Hauppauge card with IR blaster port on it that I had to go to USB-UIRT. I will have additional Hauppauge cards if I move to Colossus so just checking in on that.
Again, thanks for any info on these matters.
Asus P5Q Premium MB, E6750, 4GB RAM, 32-bit XP Pro SP3, 3Ware 9590SE controller, 80GB 7.2K Laptop boot drive w/SuperSpeed Cache Utility & eBoostr, (1) KWorld ATSC-110, (1) 950Q USB, (1) 2250 tuner, (1) HD-PVR using USB-UIRT, (1) 1600 Dual card, (1) DVICO Fusion 5 Gold, (1) Hauppauge 1250, (1) Hauppauge 2250, 8 various storage HD's, NEC-based x1 USB add-on card, 2 outdoor antennas capturing 2 different OTA markets, Dish Network w/HD Receiver for HD-PVR. |
Hauppauge only supports using one IR Blaster. IF you have multiple Hauppauge devices installed, the IR Blaster will only work on one of them, and you can't select which one (I think which ever device was detected last by Windows is the one that gets enabled).
I had not heard that the Hauppauge blaster didn't work with Dish, but it is possible. I know that there are different frequency ranges for IR blasters to use. I recall reading somewhere that Dish used a different frequency range than most. If you use the USBUIRT product, they have two versions - the more expensive one supports a wider range of IR frequencies and I think this may be required for DISH.
does dish have a 1394 port? That's how I control my Cox cable set top box due to the Hauppauge restriction.
Sage 9 server = Gigabyte AMD quad-core - 4 gigs - integrated ATI HD4200 chipset - SSD boot, Hitachi Deskstar show drives. HD-PVR - Colossus - Win7 32 bit. HD200/300’s networked. HDHomerun tuner. "If you've given up on Weird Al, you've given up on life" - Homer Simpson |
Not that I am aware of; I was just hoping that with upgraded drivers I could use a Hauppauge IR Blaster rather than my USB-UIRT. But, no big deal. Thanks for your help. I'll poke around and see if it has FW port. I'm doubting it - I don't think the VIP 211-K's have those.
Asus P5Q Premium MB, E6750, 4GB RAM, 32-bit XP Pro SP3, 3Ware 9590SE controller, 80GB 7.2K Laptop boot drive w/SuperSpeed Cache Utility & eBoostr, (1) KWorld ATSC-110, (1) 950Q USB, (1) 2250 tuner, (1) HD-PVR using USB-UIRT, (1) 1600 Dual card, (1) DVICO Fusion 5 Gold, (1) Hauppauge 1250, (1) Hauppauge 2250, 8 various storage HD's, NEC-based x1 USB add-on card, 2 outdoor antennas capturing 2 different OTA markets, Dish Network w/HD Receiver for HD-PVR. Last edited by Savage1701; 05-19-2015 at 06:02 PM. |
Colossus vs. HD-PVR bitrate/quality question | Savage1701 | Hardware Support | 6 | 05-19-2015 08:51 AM |
Lost an HD-PVR, have question on Colossus | Beefcake550 | Hardware Support | 6 | 05-04-2012 11:21 PM |
Beta 7.1.7, Colossus, & Bit Rates Question | Savage1701 | Hardware Support | 2 | 05-07-2011 09:54 AM |
HD PVR or Colossus? | twollman | Hardware Support | 20 | 03-23-2011 01:29 PM |
Colossus not getting EPG | Crunch | SageTV EPG Service | 2 | 03-10-2011 12:45 PM |
