Old 03-25-2007, 05:10 PM
HD on Linux
So, I have been thinking about going to Linux on my rebuild of my Sage server, for a couple of reasons (mainly because buying a copy of Sage Linux is cheaper than buying another copy of Windows XP or Vista). I know that sage states the Hauppauge cards are supported, but are there any other cards supported? If there are linux drivers, can I run other capture cards? Also, what about HD cards? Anyone having any luck capturing from HD? It sounds like it is still a crap shoot as far as HD on linux. I will only be using as a server and not playing anything on the linux box. What about transcoding for MVP use (HD to SD on the fly)? I know it is OEM only and only a small sect of the population uses it, so that is why I am reaching out to all of you, before I make the plunge.
Old 03-26-2007, 09:01 AM
_Demo_ _Demo_ is offline
Send a message via ICQ to _Demo_
You should be able to use any ota HD or clear qam tuner card that is compatible with linux. I have been using an avermedia a180. Depending on the card you use you might need to use a more recent linux kernel.
Transcoding is the same in both windows and linux. You will need a recent processor to be able to convert hd to sd.
_Demo_
HDHomeRun success story jbarr Hardware Support 9 02-22-2007 04:46 PM
Set HD preferences for a specific show? bwillet SageTV Software 1 02-19-2007 01:42 PM
Can this PC do HD? dholmes97 Hardware Support 4 02-15-2007 09:23 PM
In search of HD quality playback garyellis SageTV Software 0 01-27-2007 09:15 AM
