Old 06-05-2008, 12:01 PM
rnewman rnewman is offline
just received my Hauppauge WinTV HD PVR
Any suggestions before I install anything?
I did upgrade sagetv already.
What does SageTV need installed from setup disk
that came with HD-PVR???
Ray
Also I just received my Sagetv HD extender
Old 06-05-2008, 12:06 PM
Brent Brent is offline
Ray
I would install and run the HD100 extender first and make sure it's in working order.
For the HD-PVR:
Do you have any other hauppauge tuners on your system already?
Are you planning to use the included hauppauge ir blaster to change channels or will you be using another ir blaster or firewire for channel tuning?
Old 06-05-2008, 02:48 PM
I just have enough drivers to run SAgetv with:
Hauppauge PVR-500 (1)
PVR-350 used for s-video capture of my HD STB
but PVR-350 will go away with new HD-PVR
Ray
Old 06-05-2008, 04:20 PM
tried to install drivers but it said it could not find device
unknown USB device in system hardware devices
why don't they talk to each other???
Hauppauge WinTV HVR 1800 CC support OldPCGUY Hardware Support 2 03-05-2008 02:02 AM
Hauppauge PVR 150 IR help please stevech Hardware Support 8 09-10-2007 10:53 AM
Hauppauge USB2 PVR weirdness phelme Hardware Support 4 05-17-2007 02:38 PM
2 Dual Tuner PVR 500's Setup in Sage jredwine2857 Hardware Support 3 11-30-2006 02:49 PM
Client software closes overnight... weird... ShadoWolf SageTV Software 39 01-24-2006 09:55 PM
