Go Back   SageTV Community > SageTV Products > SageTV Mac Edition
SageTV Mac Edition Discussion related to the SageTV Media Center for Mac edition. Questions, issues, problems, suggestions, etc. relating to the SageTV Mac edition should be posted here.
Old 11-14-2008, 06:48 AM
HokiePerogi HokiePerogi is offline
New Drive Deteced Annoyance!
I have my iMac set to run Time Machine. The data store for time machine as on my NAS which is an AFP share. Whenever Time Machine makes a back up, it remounts the AFP share in order to access the NAS where the sparcedisk is.
Everytime Time Machine mounts the AFP share, the "A new drive has been detected" message box comes up. Okay, so that isn't too annoying. HOWEVER, the box opens up several times on top of itself. So I find myself clicking close or hitting ESC TONS of times to clear the message.
In this mornings case, I left the front end up and running on my iMac for three days without using the computer. I've clicked Close/ESC over 50 times now and I'm still getting the message.
How can I fix this issue? I consider this application bug as well. This feature needs a KILL switch in the preferences.
Old 11-14-2008, 06:57 AM
doc doc is offline
I've never used the mac version, but on the windows version you can go
Setup - detailed setup - customize
find 'Display Pop-up when a new drive detected' and set it to disabled.
Old 11-14-2008, 06:59 AM
BFisher BFisher is offline
There is an option to do it, I saw it yesterday. If you go into the Detailed Setup, Customize, near the bottom is an option "Display Pop-Up when a new drive is detected". Set that to Disabled.
Old 11-14-2008, 07:03 AM
Did you look for the option to turn it off, or just assume there wasn't one? Go to Detailed Setup -> Customize -> Display pop-up when a new drive detected.
In the PDF manual for v6.4, this is documented on p. 194 and p. 100.
If that doesn't work, only then would it be a bug.
Old 11-14-2008, 08:09 AM
Shoot. I'm not sure how I missed that option. Thanks for pointing it out.
I'm sure toggling the option will fix my issue.
Thanks again.
afp, imac, message, new drive, time machine
Help with a SATA drive issue yacht_boy Hardware Support 5 11-01-2008 12:47 PM
Cloned system drive, now playback error navels SageTV Software 1 10-03-2008 01:11 AM
Question on replacing recording drive Fountainhead SageTV Software 2 01-12-2007 09:15 PM
? About Moving Recordings to Another Drive geogecko SageTV Software 14 12-05-2006 06:43 PM
Hard drive not recognized by name robinson Hardware Support 9 08-25-2006 08:07 AM
