Old 12-22-2008, 08:05 PM
Techno Techno is offline
Directv serial control stopped working after HD PVR install
Hello, I was wondering if anyone can help me with this issue, a couple Of days ago I bought a HD PVR, I was already running a 1600 for Qam and was using the Svideo Input for My LD lss-3200 Directv receiver everything worked at that time on sage 6.4. after installing the and then uninstalling the HD PVR (I gave up on it) I had to do a HWclear and reinstall the 1600 drivers to get everything working again. But the serial control does not work it installed as far as I can tell its an option in the source details with the right com port. I can run directv.exe from the command line and it works but sage wont use it. the only thing I can find that seems odd is if you choose remote control options from the source details setup menu the options are digits per channel -1 delay between codes -1 and delay between channel change Null msec.Now I know I could set these before but when I try it takes the digit but doesn't change.
Does anybody know if theres a config file so can change these manually?
Old 12-26-2008, 12:19 PM
1Fatman 1Fatman is offline
Hi, did you find a solution to the digits per channel -1 problem yet. I seem to have the same problem. I was trying to install the new caller id xml and when i restarted sage I seem to have lost all my properties for sagemc and all my remote codes. I got my codes re-learned and sagemc all set back up but I still have this problem where I cant change the digits per channel off of -1. So it wont let my usbuirt change my dish boxes channel.
Simple utility to control multiple USB or Serial HD DirecTV STBs jchiso Hardware Support 15 02-19-2009 06:27 PM
6.5.1, HD PVR with Mac? GregT SageTV Beta Test Software 7 11-22-2008 02:23 AM
DirecTV Serial Control -- new issue with 5.0? Surtr Hardware Support 0 08-05-2006 10:26 AM
Got DirecTV Serial Control in SageTV working with Hughes HAH-SA ? What STBs do work ? kennethadams102 Hardware Support 21 03-12-2005 03:48 AM
Directv Serial Control Stopped Working DrWorm SageTV Software 1 07-30-2003 01:45 PM
