View Poll Results: What format do you use for Movies?
.VOB 36 50.00%
.MKV 15 20.83%
.AVI 7 9.72%
.ISO 0 0%
.MPG or .MGEG 9 12.50%
.WMV 0 0%
.XVID 0 0%
Other (Please explain) 5 6.94%
Voters: 72. You may not vote on this poll
Old 12-23-2008, 05:48 PM
vexhold's Avatar
vexhold vexhold is offline
Video Formats
Hi all,
Just wondered what file format the majority of people use for Ripped Movies.
Old 12-23-2008, 06:55 PM
MattHelm MattHelm is offline
Nero's .mp4.
Old 12-23-2008, 08:56 PM
HelenWeathers's Avatar
I use some sly software to rip my Blu-ray movies and TSMuxer to output the movie portion only to .ts files. If Sage likes .ts files, then I do too. I do have to downmix the audio to DD 5.1, but TSMuxer makes that part of the one-step mux process.
Old 12-23-2008, 10:17 PM
If by movies you mean DVDs, and if by "VOB" you mean DVD file/folder stuctures, then:
VOB
I haven't decided yet how I'm going to handle Blu-ray/HD DVD, but it will be as close to native as possible.
Old 12-23-2008, 10:33 PM
S_M_E S_M_E is offline
Originally Posted by MattHelm View Post
Nero's .mp4.
Ditto, although now I just rip VOBs sometimes too...
Old 12-23-2008, 11:07 PM
bastafidli bastafidli is offline
The same. Nero .mp4, it supports chapters, multiple audio streams, subtitles. Of course SageTV still doesn't support them.
TV: Samsung UN46D8000
Server: Intel Core i3 540, 4G RAM, Matrox G450, 70GB EXT3 encrypted software RAID1 system drive, 1TB XFS tv recording drive, 2TB EXT3 encrypted data drive mirror across 2 machines, 2TB EXT3 encrypted media drive mirror across 2 machines, CentOS 6 64 bit, Experimenting with DNLA servers
1Gb wired network
Disconnected after G day[HD 100 Media Extender, Placeshifter 7.x, SageTV 7.x, HDHomeRun]
Old 12-24-2008, 09:26 AM
SWKerr SWKerr is offline
mkv container with h.264 and AC3 audio.
I was using Nero ad Mp4 for awhile but changed to Megui and mkv. The Mp4 has more widespread support on other devices right now but you are stuck with AAC audio.
Nero Recode making an mp4 is easier to use for DVDs but I think the quality is better with Megui. Also Nero will not do the BluRay rips. You can easily do mp4s with Megui if you want.
You can shrink the files size of a VOB by more than half and not see the difference with h.264 files. It is newer and better. The h.264 will take more cpu to decode.
Old 12-24-2008, 09:49 AM
rrhorer rrhorer is offline
Nero's .mp4.
Add another for Nero's .mp4 (aka nero digital).
unRAID Basic Server, Sage & OpenDCT Dockers, Core i3-8100, 8G Memory, HDHR Prime, HD300 Extender, Shield & Android Miniclient, Harmony Hub/Remote
Old 12-24-2008, 11:59 AM
TakeFlight's Avatar
TakeFlight TakeFlight is offline
VOB
I'm with you on this. I hate the thought of knowing what I'm watching is not as good as it can be. I've got a little over 1TB of DVDs on my Sage server on a RAID5 volume. I too don't know what I'm going to do about Blu-ray and have just been holding off on even going down that road because of the tremendous space requirements.
Pegasus - SageTV/HomeSeer Server: Core2Duo 1.8GHz, 1GB, 1.5TB RAID5, 2.25TB RAID5, Radeon X1050, (2) Hauppauge PVR250 (only used for security cameras now), SiliconDust HDHomeRun, Hauppauge HD-PVR, WinXP Pro
Prometheus - SageTV Client: Core2Duo 2.66GHz, 1GB, 500GB, GeForce 8400GS, WinXP Pro, 848x480 to InFocus SP4805 projector on a 78" screen
HD Theater (HD200) connected via HDMI to Panasonic TH-42PX60U 42" plasma
web server plugin | 2 MediaMVP Extenders | FiOS TV
Old 12-24-2008, 01:55 PM
Lucas Lucas is offline
Same here.
I am also thinking about what to do with BR.
One pleasant thing is that the new HD200 plays my BR m2ts files(STREAM dir) directly without any issues yet(of course no HD audio formats yet).
Rather than using TSMuxer or packaging in mkv I am thinking of just renaming the main movie m2ts file....
I will have to upgrade all clients to HD200 though.
3 x HD300s
Old 12-24-2008, 02:14 PM
hemicuda's Avatar
hemicuda hemicuda is offline
It's a mix for me. VOBs for rips unless I just want the movie then it's MKV/AC3. All my old stuff is DIVX/AVI, but I'll replace that over time. Then there's the stuff available on Netflix Instant Queue. I just dumped about 180Hrs(est.) of programming because I can get it in better quality than on my analog tuners. That's a wee bit OT though.
And I have a 1TB drive arriving today (though I had a WD failing the other day). sheesh
Server: MS Win7 SP1; FX8350 (H2O cooled); 8GB RAM; Hauppauge HVR-2250 (OTA); HVR-1800 (OTA); SageTV 9.1.5.x; 12+TB Sage Storage
Clients: HD300 x2; HD200 x2; Placeshifter
Service: EPB Fiber (1Gb); OTA (we "cut the cord"); Netflix, Hulu, etc.
Old 12-25-2008, 02:44 AM
garmpe garmpe is offline
VOB's for me too but would also use Nero Digital if it worked in SageTV.
Old 12-25-2008, 04:31 PM
valnar valnar is offline
The question doesn't make sense. If you mean DVD, then DVD format of course. I suppose that is VOB... although it could also be contained within an ISO file too. But since Sage doesn't really support ISO, I rip them to the DVD folder structure. I guess that makes it VOB.
For HD though, I rip to MKV since it supports multiple audio, chapters and subtitles, even if Sage does not (yet). I voted for MKV. As far as Sage support is concerned, I see no reason to use WMV, AVI, MPG or MP4 since MKV is a better container in every way.
Server: ASUS P7F-E, Intel Xeon x3440, 4GB RAM, DR-400-6 RM case, 2x Addonics Disk Array 3SA, 7TB disk,
2x Nvidia DualTV, 2x HDHomeRun, HD-PVR 1212, Win7-32bit, Sage 7 latest
Client 2: HD300 on Vizio 40"
Old 12-25-2008, 09:52 PM
mcaron1234's Avatar
mcaron1234 mcaron1234 is offline
What he said!
Matt
Old 12-26-2008, 09:21 AM
sandor's Avatar
sandor sandor is offline
...I hate the thought of knowing what I'm watching is not as good as it can be...
i used to think like this, then i went on a movie-watching spree, and thought "Why am i wasting 6.5 GB on this crappy movie when i could waste only 2.8 Gb if i give it a good h.264 encode?"
Granted, i am not in to movies, i dont think i have ever looked at the extras, commentary, deleted scenes, etc on a DVD - and i probably never will, i just have no interest in them.
Music, on the other hand, i could never imagine anything but FLAC or ALAC - no matter how close to original quality "they" say the new CODECs may be
MacBook Core2Duo 2 ghz
nVidia 9400M GPU
46" Sammy HLP4663 720p DLP
2x HDHR, all OTA
QNAP TS-809:
12.5 TB for Recordings/Imports/TimeMachine/Music
HD200 via 802.11n in Living Room
802.11n client in bedroom
Old 12-27-2008, 09:28 PM
vexhold's Avatar
For those using MKVs and handbrake. I have been attempting this format as it supports movie playlists.
What settings in handbrake do you use? I ask because when I use the default settings (either film or animation) I get alot that wont play in SageTV.
Old 12-27-2008, 10:08 PM
vexhold,
Please see this thread.
Old 12-27-2008, 11:14 PM
vexhold's Avatar
I am only ripping SD DVD's so HD is not my problem.
I just want to know what settings people are using for handbrake to get the best possible quality without using the .vob which doesnt support playlists.
Old 12-28-2008, 12:52 AM
I don't know what the actual settings are but I just use this tool to make mkv out of dvd:
http://forums.sagetv.com/forums/showthread.php?t=34527
It's drag and drop but it uses handbrake.
Video files being imported as music, help please? mherce SageTV Software 4 06-13-2008 09:44 AM
Nvidia Decoder / Video quality problems brundag5 SageTV Software 2 01-12-2007 06:58 PM
Video is working, now for sound otakucode SageTV Software 2 01-03-2007 05:19 PM
