Old 10-19-2009, 10:57 PM
Nick_W Nick_W is offline
S3 Suspend And Resume Issue.
Hi,
I have a real problem with S3 suspend and resume when SageTV is FSE. Basically the system hangs on resume with a black screen.
I run in client/server mode on the same machine. If the client is not open on suspend then everything is fine. SageTV wakes to record etc., and then goes back to sleep.
Do others have this issue, and is there a way that I'm not aware of to do this properly (e.g. minimise SageTV before suspend).
TIA,
Nick,
Old 10-20-2009, 12:15 AM
Rico66 Rico66 is offline
It's not that extreme in my case. But I noticed that Sage doesn't always resume properly, e.g. when in the music screen it doesn't display albums correctly, the art is not displayed and you essentially can't play anything. This doesn't repro 100% of the time. I had the rare case of a black screen as well, but only a few times.
Bottom line for me is that I always close the client app before going into standby, since it doesn't handle standby 100% accurate.
The server is not affected by this, so recordings are ok.
Old 10-20-2009, 12:36 AM
Hi,
But what do you do when it resumes if the client is closed? I'm thinking -WAF
Regards,
Nick.
Old 10-20-2009, 10:27 AM
My wife isn't that much into tv watching, so that's not that big of an issue
But, I've my Harmony remote programmed that it always starts the Sage client as a startup action.
Old 10-20-2009, 10:37 AM
SOLVED
Was a BIOS setting; not sure how it got changed!
Regards,
Nick.
Old 10-22-2009, 07:57 PM
jrh995 jrh995 is offline
Was a BIOS setting
And that BIOS setting was ???? for others that might have a similar problem?
John
Power button suspend issue vca SageTV Software 3 07-06-2008 07:01 AM
Getting only monitor to sleep/suspend. cejota3 SageTV Software 2 04-01-2007 01:42 PM
v6.1.3, no suspend. camus SageTV Beta Test Software 5 02-24-2007 05:43 PM
Suspend Favorites Ken C SageTV Software 5 08-14-2006 08:33 PM
Suspend and resume with SageTV mwhitlock SageTV Software 340 03-16-2006 11:18 AM
