Old 05-20-2010, 06:16 PM
Jackal24 Jackal24 is offline
Malore menus & other hidden extras
Anyone up to the task of redoing the malore menues for v7? I don't have the skills and I hate the way that the default stv lists recorded programs.
Old 05-20-2010, 06:21 PM
andy will get to it during his copious amounts of free time (in other words, yes it will be converted, and no he can't say when)
See here
Check out TVExplorer
Old 05-20-2010, 06:31 PM
bsung bsung is offline
Oh no! I was planning to upgrade tonight but if there aren't any malore menus, I might have to reconsider since that's what my wife is used to.
Old 05-20-2010, 06:33 PM
they're there they just havent been converted to the new v7 theme yet (ie they look the same as the v3 ui)
Old 05-21-2010, 11:31 AM
mcaron1234's Avatar
mcaron1234 mcaron1234 is offline
V 7 Malore recordings style
I'm hoping that one of the SageTV folks can answer this for me. I know that the Malore view is not officially supported, but will this view at least get the new skin? Alternatively, if the default view in recordings had the ability to show or sort by episode number I wouldn't need/want the Malore view.
* merged *
Old 05-21-2010, 02:46 PM
skyeclad skyeclad is offline
I also would love new UI style Malore menus but not the ones where the top half of the screen is taken up with information about the program. The SageMC malore menu plugin version uses more screen real estate for the program and episode list and seems more efficient to me.
+100 for Malore Menu's...they simply are better!
Old 05-22-2010, 05:13 PM
Brent94Z Brent94Z is offline
Drive space remaining now gone from header?
Hey Guys!
In V6 I had the custom feature to show how much recording space was available as well as how many shows and the space they were going to take up for the next 48 hours.
I see these options in V7 and I have it all turned on but the only time I see it is when I switch to the old blue style UI. Am I doing something wrong or is this menu bar not able to be there with the new UI? I really liked having that info always up there in the header and hope I'm just missing something!
* merged *
Old 05-22-2010, 05:31 PM
blade blade is offline
As far as I know it's not working in v7 yet.
Old 05-22-2010, 05:38 PM
Thanks, Blade! I do hope it is something that IS added for the final release as I have come very used to having that info right there
Old 05-22-2010, 06:03 PM
tmiranda's Avatar
tmiranda tmiranda is offline
I just ported the Phoenix Fanart to the Malore Menus so they certainly are there. Enable them the same way as before.
I plan on porting my other Malore based STVi's as well. If you have a preference as to which please let me know. I'm fairly sure I'll do "Select and Batch Delete" next, because I use it all of the time.
Old 05-26-2010, 10:13 PM
tonysathre tonysathre is offline
Malore Menus
I've heard a lot of talk about the Malore menus. From what I understand, they just a two pane list view? What are the benefits of using them and what do they look like? Could someone post some screenshots of them please?
Thank,
Tony
* merged *
Old 05-27-2010, 03:07 AM
wado1971's Avatar
wado1971 wado1971 is offline
The Malore Menus are already incorporated into both v6 & v7 of SageTV. See this post to get SageTV setup to view them.
http://forums.sagetv.com/forums/showthread.php?t=12520
The only issue with the v7 Malore Menus it that they retain the v6 background/layout - but still usable.
Old 05-27-2010, 03:35 PM
Oh I see. I thought it was a plugin, but I couldn't find it in the repository. Thanks
Old 05-27-2010, 05:29 PM
aedgington aedgington is offline
They are also my biggest stumbling block for WAF. The new recordings screen doesn't offer the same information and so we're back to square one (fanart-less).
It seems kind of silly that as popular as the malore menus are, that they weren't updated, or the new menus not based off of them.
Old 05-27-2010, 10:21 PM
It has already been said that the malore menus will be updated when Opus gets time.
Old 05-29-2010, 06:01 AM
mzup mzup is offline
This may be answered somewhere else but haven't found it. Is there a way to customize the screens like we were able to do with sagemc? The usual 'wife doesn't like change' comes into play with the new layout. I just installed last night and she has yet to see it so was hoping there was some way to make it more like the way i had it setup. Some things that I did was to add the guide right on main screen as well as recordings. This way all she would have to do is one click to get to those screens.
Old 05-29-2010, 06:37 AM
wado1971's Avatar
The v6 default version of Malore Menu has an option to modify the size of the top half information screen built in - as you select the option to increase the number of listed rows, the info screen is reduced. It also allows you to remove the 'other view' bars on top. So you should be happy with the default version as long as this functionality is ported over.
Old 06-01-2010, 08:31 PM
dwycoff's Avatar
dwycoff dwycoff is offline
Cool Malore Feature
The one feature my wife uses most and can't live without is where you can hit the number keys and go directly to that alpha title equivalent - example - go to movies and press 3 will get you to "D's" press 8 will get you to "T's". With about 900 movies it is a real time saver versus scrolling through or searching on an individual title.
Old 06-02-2010, 02:13 AM
can3gxw can3gxw is offline
OK, OK, OK - I'm not a noob, but apparently I haven't seen all that Sage has to offer...
What exactly are "Malore Menus"? Can someone post a few pics of what they look like?
Gregg
Old 06-02-2010, 04:56 AM
tmiranda's Avatar
Go to the "System Information" menu and press "5309" without the quotes. Then view your recordings and you'll see. To revert back to the default go back to the System Information menu and press 5309 again.
Tom
CS Icons on shows in malore menus? CarlR SageTV Customizations 1 09-18-2009 09:13 AM
Malore Menus brandypuff SageTV Customizations 2 08-14-2009 12:10 PM
Customize malore menus text? nyplayer SageTV Customizations 1 07-21-2009 09:55 AM
Malore menus in 6.2 srothwell SageTV Customizations 2 10-08-2007 06:55 PM
Malore menus slow to load on MVP Gaurav SageTV Customizations 0 03-07-2006 02:21 PM
