Old 10-07-2016, 10:54 AM
CollegeProject CollegeProject is offline
Updated Sage v9 jar and bmt
Now the webserver is not responding after updating BMT to latest version.
Nothing shows failed or update available in the plugins. I restarted sagetv service/computer and even the webbrowser through jetty. Any others seeing this?
I get the following error when trying to access
HTTP ERROR: 503
Problem accessing /bmt/. Reason:
    SERVICE_UNAVAILABLE
Powered by Jetty://
Old 10-07-2016, 11:28 AM
HTTP ERROR: 503
    SERVICE_UNAVAILABLE
Powered by Jetty://
What version of JAVA are you using?
Old 11-06-2016, 01:06 PM
DaveS DaveS is offline
I am seeing the same thing after reinstalling the Windows version of 9.09. I'm using Java 32b v7 update79.
I just updated Java to 8_111 and it works now
Dave S
Windows 10, Sagetv 9.1.10, OpendDCT 5.28, 8gb ram, HDHR Prime, 3 HD300
Old 11-14-2016, 03:36 PM
ptzink ptzink is offline
I am getting the same error. I tried updating to java 8_111 (though I knew better, I thought I would try it) and that borked my whole web app interface. So I downgraded back to java 7_u79. All is well except for the 503 error when trying to access BMT. My SageTV version is 9.0.9.441. Anyone else?
Server: SageTV Media Center 7.1.19, Windows 7 Home Premium x64, Pentium Core2Duo, 4GB RAM, (1) Hauppauge HVR-2250, (1) Hauppauge HVR-1600, 1.5 TB of recording space
Android MiniClient: Nvidia Shield TV (16GB) HDMI out to Samsung LN46C630 46" LCD
Extender: STP-HD300, beta firmware "20110506-0", HDMI out to LG 37LD450 37" LCD
Old 11-14-2016, 03:58 PM
Korny Korny is offline
The only thing that 1.8 breaks is the /app function, but you can access all the other Sagetv web function from root of directory, so for me HTTP://192.168.0.2:8085(I changed the default port)
Intel I7 4790k @ stock speeds, 32 GB of ram. 8TB of recording space.
Old 11-14-2016, 04:16 PM
I tried accessing BMT directly when 8_111 was installed. I got to the page, but got the following errors:
Phoenix Error Failed to get status for: Phoenix
SageTV Error Failed to get status for: SageTV
System Messages Clear All
Old 11-15-2016, 05:57 PM
Still not working. Can anyone advise on how to downgrade?
Old 11-15-2016, 06:42 PM
If you post a log file, I can review it. BMT works with Java 8... since that is what I run.
Old 11-15-2016, 06:47 PM
Stupid question, does bmt log to the sage.txt file or does it have its own log?
Old 11-15-2016, 07:36 PM
I would start with sagetv_0.txt log file... since if bmt is not working there won't be anything the bmt log. you can also post the logs/phoenix.log as well.
Old 11-15-2016, 08:52 PM
Is there any way to get it running on the old Java version? I prefer to use the /apps web interface. If not, is there a way to downgrade? Or get /apps running with Java 8?
Old 11-16-2016, 05:16 AM
probably not... Likely with new releases of plugins, and maybe even sagetv, Java 8 will become the minimum, especially since Java 7 is no longer supported by oracle.
Old 11-16-2016, 08:23 AM
I am definitely cool (and would prefer) to update to Java 8. I just happen to like the /apps web interface as I have several web apps (BMT, SageAlert, web interface, mobile web interface). Has anyone gotten the apps interface to work with Java 8?
Old 11-16-2016, 09:57 AM
Skirge01's Avatar
Skirge01 Skirge01 is offline
I have all of those working under Java 8. That doesn't mean they work 100%, since I haven't checked every single screen/option to verify, but I haven't yet run into anything which didn't work.
Software: SageTV 7
Old 11-16-2016, 10:01 AM
Sorry, my post was probably a little confusing. What I was trying to say is that I like the http://<server>:<port>/apps landing page that displays all of your web apps in a list as I frequently bop in and out of the different web apps, rather than having to navigate to each app url individually. As far as I know, the /apps landing page does not work correctly in Java 8.
Old 11-16-2016, 10:35 AM
Skirge01's Avatar
Ah, no problem. In that case, you're correct that it doesn't work.
Software: SageTV 7
Old 11-16-2016, 11:32 AM
I updated back to Java 8_111. BMT and other web apps are working fine. /apps launcher page is broken. Would love to have /apps working, but oh well. Thanks.
Old 11-16-2016, 12:10 PM
I took someone else's advice in another thread to create a static HTML page with the links in it. That works fine as a landing page for me now. Unfortunately JAVA 8 broke some things in the web interface so I can't do things like schedule recordings on the mobile view. Double unfortunately is that I can't go back to JAVA 7 without getting rid off things like Phoenix and BMT unless someone has a way to get the older versions.
Old 11-16-2016, 01:41 PM
Good idea. Anyone have a sexy static landing page I can steal?
Old 11-16-2016, 03:05 PM
This is the link to the suggestion: https://forums.sagetv.com/forums/sho...9&postcount=65
Mine isn't sexy, but looks like this:
<html>
<body style="font-size:32px">
<h1>The Stein Family TV</h1>
<hr>
<p></p>
<table style="border:1px solid black;font-size:32px">
<tr>
<th style="border:1px solid black; background:lightgray">Remote Access</th>
</tr>
<tr>
<td style="vertical-align:top;padding:15px;border:1px solid black">
<p><a href="/sage">Web Interface</a></p>
<p><a href="/sagem/m">Mobile Web Interface</a></p>
</td>
</tr>
<tr>
<th style="border:1px solid black; background:lightgray">Tools</th>
</tr>
<tr>
<p><a href="/livepvrdata/events">Live PVR Data</a></p>
<p><a href="/bmt">Batch Metadata Tools</a></p>
<p><a href="/sagealert">Sage Alert</a></p>
<p><a href="/sagex/api">Sage API</a></p>
<p><a href="/sagex/streaming">Phoenix Media Streamer</a></p>
</td></tr>
</body>
</html>
Updated to HDHR v20100213 - Won't Work in Sage Ron Hardware Support 3 02-25-2010 11:36 AM
Sage guide hasn't updated channels tvmaster2 SageTV EPG Service 2 04-05-2008 03:34 PM
Updated Sage, Lost all HD channels BlueH2O SageTV Software 3 03-13-2008 09:07 AM
Hdhomerun and mAc! Hopefully sage will be updated soon for support! mohanman SageTV Mac Edition 10 10-01-2007 09:47 AM
Updated to Geforce 6200, now Sage crashes dflachbart Hardware Support 13 06-06-2006 08:10 PM
