Old 09-27-2017, 09:07 AM
BobbyDing's Avatar
BobbyDing BobbyDing is offline
Update/Upgrade Question
So I just discovered that the client on my windows server will no longer connect to the sage on my unraid server because of version differences (been a while since I tried). They are both V9. The windows stuff is behind though. Can I just copy in the latest sagetv7.xml (and where would I find just that file)? Or would I need to run the latest open source installer(s)?
Thanks so much!!
Bobby
Athlon II Quad Core 3Ghz, 8GB Ram. 12GB Storage. 3 (x4) HDHR for OTA Across 2 Cities, HD200, 2x HD300.
Old 09-27-2017, 09:15 AM
wnjj wnjj is offline
Thanks so much!!
Bobby
The Windows stuff just caught up a couple days ago. Run the installer for 9.1.7.
Old 09-27-2017, 11:10 AM
Tiki's Avatar
Tiki Tiki is online now
Sage Clients and Servers must always be running the exact same version number, else you will likely have problems.
This is not so important with Placeshifter clients, but with full Clients you have to upgrade client and server at the same time. There may be some edge cases where you get lucky and two different versions happen to work ok together, but generally you should not expect this to work.
Updating Sage7.xml will not help with this. Sage.jar is probably the most important thing, but there may be other important differences. It is generally not recommended to just update individual files anyway - you should use the installer. Also, if you've manually updated individual files in the past, you will need to run the installer twice and choose the "repair" option the second time or if won't install properly. When you run the installer to update Sage, be sure to double check the installation path to be sure you are installing in the same place (and always make a backup before doing anything).
,USBUIRT (multi-zone)
Source:
Comcast Cable
HDHR, HVR-2250
Old 09-27-2017, 06:38 PM
jusjoken jusjoken is offline
Actually the windows 9.1.7 was available prior to the Linux one , but who's counting
They are both available so ALWAYS best to use the installer....just run it a second time (select repair) if previously you manually made changes to files normally installed by the installer.
k
Upgrade to STV9, some plugins will not update Ender SageTV Github Development 6 10-27-2016 06:28 AM
Suggestion: Plugin menu wording... upgrade & update Brent94Z SageTV Beta Test Software 3 06-07-2010 04:15 PM
To upgrade or not to upgrade - That is the question.... scoful SageTV Software 3 05-31-2007 05:35 AM
SageTV's instruction re 6.1 upgrade (update) stevech General Discussion 4 04-13-2007 05:19 AM
EPG Update question Wally SageTV EPG Service 8 08-03-2003 09:11 PM
