Old 10-01-2018, 08:11 AM
Unable to Install Comskip Playback plugin...
When I try to install the Comskip Playback plugin it fails on download from Bintray.
Old 10-01-2018, 03:42 PM
trk2 trk2 is offline
Interesting. I just installed the plugin without issue. Can you install any of the plugins hosted on Bintray (here is a list)?
Old 10-01-2018, 05:27 PM
Just tried it no go ....
Old 10-01-2018, 06:21 PM
I had the same issue a week ago. I was unable to install any plugins that were hosted on Bintray and, possibly unrelated, was unable to pull any meta data from TMDb. Since I wanted to make some hardware changes anyway I ended up doing a fresh install with a backed up wiz.bin and everything has worked since. Now I regret not investigating further since I assumed my issue was a one off...
Old 10-01-2018, 07:03 PM
JustFred JustFred is offline
It can be downloaded directly from here: https://bintray.com/jrekiwi/SageTV/C...mskip_Playback
Maybe send a PM to the owner?
Old 10-01-2018, 07:44 PM
Thanks I did PM john
Old 10-02-2018, 02:14 AM
JREkiwi's Avatar
JREkiwi JREkiwi is offline
I've updated the repository to point to an alternate bintray download path.
John
Old 10-02-2018, 08:30 AM
John
Thanks John that fixed it.
Old 10-03-2018, 09:40 AM
perfessor101 perfessor101 is offline
Where an I download the updated repository path?
Hello,
Iím having problems downloading from bintray also
What do I have to update?
Thanks for your time,
Bobby
DNS servers are googles public and quad 9
SageTV Server: Windows 7 64Bit, Phenom II X6 1090T, Asus M4A89GTD-PRO/USB3 (AM3), ATI Radeon HD 4290, 2 x KHX1600C9D3/4GX, 4 x HD-PVR2 Gaming, , 4 x 320GB recording drives, 2 x USB-UIRT, SageTV Server Beta
SageTV Client & 2 x HD-300 Extender.
40.8TB unRaid 6.6.5 media server
Old 10-16-2018, 09:40 AM
can't download plugin updates at all with a fresh install ...
Hello
Help
Fresh Install of SageTV 9.1.9 can't install any plugins ... bintray erroring out?
can't install SageTV 9.1.10 yet as bintray is saying forbidden
using google, opendns and quad nine as dns servers
tried with java 7 and 8
does SageTV 9.1.10 help with this?
Would like to install the webserver as SageTV is attempting to record every instance of favorites with generic epg info. I mark about 60 shows a day as watched. The Gui locks up for 10 minutes at a time so I can't do it that way.
Thanks for your time and help,
Bobby
Old 10-16-2018, 10:05 AM
how hard would it be to manually install the jetty webserver?
Old 10-16-2018, 10:09 AM
tried downloading https://dl.bintray.com/opensagetv/sa...s-2.3.0.14.zip manually in chrome and it says forbidden ...
I'll try logging into github on my SageTV server ... and what is bintray ...
Old 10-16-2018, 10:11 AM
wnjj wnjj is offline
Bintray is having problems right now. There are other posts talking about it. Sage binaries will likely need a new home.
Old 10-16-2018, 10:22 AM
logged in to bintray and tried to download a few more plugin files and bintray still replies with a single word ... forbidden
does the plugin system login to bintray for downloads or?
Old 10-16-2018, 08:33 PM
jusjoken jusjoken is offline
Bintray seems to be working again.
SlimPlayer plugin install fails on GKusnick plugin scottkoontz SageTV v9 Customizations 11 01-07-2017 07:34 PM
Unable to install Gemstone panteragstk Gemstone for v7 2 09-01-2016 04:32 PM
Comskip Playback plugin not working after update alfi33 SageTV v9 Customizations 9 06-07-2016 01:24 PM
Plugin: Comskip Playback for Default STV (with Scale Correction) v.1.5.6(Fuzzy) Fuzzy SageTV Customizations 10 07-01-2010 03:50 PM
Comskip Playback Plugin for EDL -- Problem davidk21770 SageTV Customizations 11 08-25-2006 12:52 PM
